can two different models of 3750 switches be stacked ?
Nasser007
kindly, can somebody confirm weather those models can be stacked or not :
WS-C3750E-48PD-EF
ws-c3750E-48PD-SF 48PoE 10G
ws-c3750E-48PD-SF 48PoE+
2 Accepted Solutions
Mark Malone
yes you stack them make sure the software matches , if the software doesn't match not all features will be available in the stack as the minor major numbers will be off in the versions
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.html#wp1223384
Major Version Number Incompatibility Among Switches
Switches with different major Cisco IOS software versions usually have different stack protocol versions. Switches with different major version numbers are incompatible and cannot exist in the same switch stack.
Minor Version Number Incompatibility Among Switches
Switches with the same major version number but with a different minor version number are considered partially compatible. When connected to a switch stack, a partially compatible switch enters version-mismatch (VM) mode and cannot join the stack as a fully functioning member. The software detects the mismatched software and tries to upgrade (or downgrade) the switch in VM mode with the switch stack image or with a tar file image from the switch stack flash memory. The software uses the automatic upgrade (auto-upgrade) and the automatic advise (auto-advise) features. For more information, see the "Understanding Auto-Upgrade and Auto-Advise" section.
Leo Laohoo
They can be stacked as long as all members are running the same IOS version (and license).
Mark Malone
Leo Laohoo
