Can we insert 2 HWIC-4ESW in 2911/k9
Narsimha Golla
Dear  all
We have cisco 2911/k9  we fixed 2  HWIC-4ESW crds in 2911. I create 4 vlan i have assigned 1 HWIC-4ESW  all vlans are working fine
when i configure 5 th vlan it assigned second  HWIC-4ESW 1 port but interface status showing up. i connected one system to that port i try
to ping that port that port notable to pinging is there any  activation for that second HWIC-4ESW  please suggest me.
Narsimha
11 Replies 11
Sandeep Choudhary
May be i am wrong but just trying to understand your question:
What i understand is ..
You have created 4 vlans and you applied on the 4 ports of 1st HWIC-4ESW card.
Now you created 5th valn and applied to one of the ports on 2nd HWIC-4ESW cards.
Now you want to ping from vlan1(Port 1) to vlan5(port5)
Do you this topology??/
        Usually you can insert 4 HWIC-4ESW cards.
Thanks for replay
interface FastEthernet0/0/0
description To RBS
switchport access vlan 10
interface Vlan10
description To RBS
ip address 10.236.112.65 255.255.255.224
ip nat inside
ip virtual-reassembly
I have connected desktop to 0/0/0
desktop ip add 10.236.112.68  255.255.255.224
         gateway 10.236.112.65
i want ping this desktop to 10.236.112.65
nkarthikeyan
Level 7
Level 7
Hi Narshima,
Yes you can have 2 No's HWIC cards in 2911 routers...
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
If that shows in your config... it should work... there might be some other problem..... Pls try reinserting the module once again.... check for inflow and outflow of packets in the inetrafces to chk the hitz
Thaks for replay
Two cards interfacess  showing in router 1 card i have assigned 4 vlasn it's working fine 2  card first port 0/1/0  i have assigned vlan10.  in this port i have conntected on pc  that pc notable communicating vlan10
description To RBS
interface Vlan10
description To RBS
ip nat inside
can you please pase the whole config??
Then only we can find the problem.
sh run ?
Have you really connected the right port? Do a "show ip int brief" to verify which port is UP.
Hi,  yes i am already using another 4 port in one more card this is the second card. But Port status is up     Thanks, Narsimha
can you show us the your whole config??
mlund
Level 7
Level 7
Hi Narsimha
You have to connect these two modules with a crossovercable.
You also have to configure "stacking partner" to get it to work.
see this for reference
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1049119
/Mikael
Thanks, same i have configured it's working but is it right?
mlund
Level 7
Level 7
Glad to here it's working.
Yes, the modules has to be connected by a crossovercable, because there is no backplane that connects the modules  together.
/Mikael
