Can we run OSPF on swith with IP base feature
knaik99
Can we run OSPF on swith with IP base feature?
if no ,solution also?
Mark Malone
yes
"OSPF for Routed Access: Starting from Cisco IOS Release 12.2(55)SE, the IP Base image supports a new feature called OSPF for Routed Access. OSPF for Routed Access is designed specifically to enable you to extend Layer 3 routing capabilities to the wiring closet. It supports only one OSPFv2 and one OSPFv3 instance, with a maximum number of 200 dynamically learned routes."
