Canceling the reset botton...
laurendvir
Hi ,
I would like to lnow is there a way to cancel the reset botten without damageing the switch?
If there is no way to do it, i would like to know is there a way to make my switches to load form a config file that i have created in the switch every time that a user push the reset botton and try to restor it to factory defalt???
Thank's
Lauren D
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I recall some later devices/IOSs have some feature to preclude normal password recovery.  Don't recall the actual feature name or IOS command.  Do recall, if you use the procedure, don't lose you passwords!
BTW, another approach is place the device behind a lock.
PS:
Hmm, just found http://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/46104-no-service-pswdrec.html?mdfid=268437963, which might have been the feature I remembered.
If so, it doesn't appear to exactly satisfy your requirement.
Joseph W. Doherty
Disclaimer
Posting
PS:
