Cannnot connect to multicast on 7600 router - while other connections can
tiki_turtle
Hello everyone. I have a 7613 / Sup720 router that has at least 30 multicast connections successfully streaming data via pim sparse-mode across different interfaces toclients. It's a cookie cutter configuration for each client basically.
However, on this particular client once PIM is enabled on his interface I can only see him as PIM neighbor and if he tries to make a connection I don't even see a (*,G). I thought that maybe it's an ACL problem on his side so I added and igmp static statement on his interface to just forward the packets...I checked the mroute table for the feed - and all I saw was the other 15 clients currently on it subscribing. I then replaced the static statement with a join-group statement thinking it may jump start the connection...still nothing in my mroute table. I switched to dense-mode and voila - I see a (*,G)...and a (S,G) too (since we run sparse-mode natively). However, once I switch back...I don't see any feeds being streamed....anything I could be looking for? The client is running sparse-mode and has the rp information for our stream...but I guess that doesn't still explain why I cannot see a join when I add a 'static-group command to their interface. Thanks in advance for the help
Giuseppe Larosa
Hello Amin,
please provide
sh ip rpf source-ip-address
sh ip pim int typex/y
where typex/y is interface to troubled customer
sh run int typex/y
sh ip pim rp mapping
and what is the G group that the customer should join
Hope to help
Giuseppe
Thanks Guiseppe
R1#sh ip rpf 142.201.219.10
RPF information for ? (142.201.219.10)
RPF interface: Vlan2013
RPF neighbor: ? (142.201.52.229)
RPF route/mask: 142.201.219.0/24
RPF type: unicast (eigrp 5)
RPF recursion count: 0
Doing distance-preferred lookups across tables
R1#sh ip pim int g12/17
Address Interface Ver/ Nbr Query DR DR
Mode Count Intvl Prior
142.201.179.209 GigabitEthernet12/17 v2/S * 1 30 1 142.201.179.210
interface GigabitEthernet12/17
description Client1
ip address 142.201.179.209 255.255.255.252
ip access-group acl_in in
ip nat outside
ip flow ingress
ip pim bsr-border
ip pim sparse-mode
ip multicast boundary yt_mcast_out
speed 100
duplex full
wrr-queue queue-limit 10 70 15
wrr-queue random-detect min-threshold 1 80 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 2 40 70 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 40 95 100 100 100 100 100 100
wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 3 95 100 100 100 100 100 100 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0
wrr-queue cos-map 2 2 2
wrr-queue cos-map 3 1 4
wrr-queue cos-map 3 2 3 6 7
no cdp enable
end
R1#sh ip pim rp mapping
PIM Group-to-RP Mappings
Group(s) 233.102.209.0/25
RP 142.201.52.1 (?), v2v1
Info source: 142.201.52.1 (?), elected via Auto-RP
Uptime: 5d19h, expires: 00:02:40
Group(s) 233.102.209.128/25
RP 142.201.52.45 (?), v2v1
Info source: 142.201.52.45 (?), elected via Auto-RP
Uptime: 16w5d, expires: 00:02:34
Group(s) 239.0.0.0/24
Uptime: 5d19h, expires: 00:02:41
Group(s) 239.142.1.0/24
Group(s) 239.142.2.0/24
Uptime: 16w5d, expires: 00:02:36
Group(s) 239.142.3.0/24
Group(s) 239.142.20.0/24
Uptime: 5d19h, expires: 00:02:42
Acl: mcc_mcast_groups, Static-Override
RP: 142.201.52.45 (?)
Acl: activ_chi_mcast_groups, Static-Override
RP: 65.175.24.150 (?)
Acl: activ_ny_mcast_groups, Static-Override
RP: 65.175.24.22 (?)
Acl: nasdaq_mcast_groups, Static-Override
RP: 198.140.52.1 (?)
142.201.178.202, 239.142.2.1), 00:02:30/00:00:59, flags: T
Incoming interface: GigabitEthernet12/24, RPF nbr 0.0.0.0, RPF-MFD
Outgoing interface list:
GigabitEthernet12/48, Forward/Sparse, 00:02:30/00:03:17, H
GigabitEthernet13/27, Forward/Sparse, 00:02:30/00:00:29, H
GigabitEthernet1/5, Forward/Sparse, 00:02:30/00:00:29, H
GigabitEthernet13/24, Forward/Sparse, 00:02:30/00:02:34, H
GigabitEthernet12/7, Forward/Sparse, 00:02:30/00:00:29, H
GigabitEthernet12/47, Forward/Sparse, 00:02:30/00:00:29, H
There are more clients Guiseppe - but here are the ones that are connected...
Thanks very much
Hello Amin,
this line may have an effect:
see
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1029655
what is the config of ACL yt_mcast_out ?
Hope to help
Giuseppe
