Cannot access wireless devices
Nikolaos Milas
We have implemented a link between two Cisco 3825 routers (R1 and R2) as follows:
R1 - Sw1 [trunk port] - Ub1 - Ub2 - Ub3 - Ub4 - Sw2 [trunk port] - R2
.1                       .2   .3     .4    .5                      .6
There is a management VLAN (#7) with subnet 10.201.2.0/24 (see specific addresses above).
The wireless devices (Ub1 - Ub4) are Ubiquiti PowerBridge M5.
Their configuration is as follows: http://iweb.noa.gr/files/ubnt-m5-20150420a.png.
(Some months ago I had started this thread, when setting things up: https://supportforums.cisco.com/discussion/12477986/using-different-native-vlans-different-ports-switch-configured-trunks)
.2 and .3 use as gateway the .1 side (R1) and the .4 and .5 use as gateway the .6 side (R2).
There is also a p2p VLAN (#8) using 172.16.1.17/30 (R1) and 172.16.1.18/30 (R2).
Native VLAN is the default (#1).
The P2P VLAN is being used for OSPF / BGP.
This setup has been working fine until recently. At some point the link went down, and we cannot access any of the wireless devices from either side!
We have noticed that if we reset any of the end Ub devices (e.g. .2) we can access it for a short while, right after the reset, and then we lose access permanently.
Can you please advise on how to proceed with resolving this situation? Any ideas/suggestions will be greatly appreciated!
The router interfaces:
R1:
interface GigabitEthernet0/0.7
encapsulation dot1Q 7
ip address 10.201.2.1 255.255.255.0
ip flow ingress
ip nat inside
no ip virtual-reassembly
ip policy route-map udp-df0
interface GigabitEthernet0/0.8
encapsulation dot1Q 8
ip address 172.16.1.17 255.255.255.252
ip flow ingress
ip nat outside
ip ospf message-digest-key 10 md5 7 xxxxxxxxxxxxx
ip ospf network point-to-point
ip ospf cost 10
shutdown
ipv6 address 2001:648:2011:101:xxxx::xxxxx/64
ipv6 enable
ipv6 ospf network point-to-point
ipv6 ospf cost 10
ipv6 ospf 125 area 0
ipv6 ospf authentication ipsec spi 256 sha1 7 xxxxxxxxxxxx
ipv6 flow monitor IPv6_cisco1 input
crypto map vpn
R2:
interface FastEthernet2/0.7
ip address 10.201.2.6 255.255.255.0
ip flow ingress
ip nat inside
interface FastEthernet2/0.8
ip address 172.16.1.18 255.255.255.252
ip flow ingress
ip nat outside
ip ospf message-digest-key 10 md5 7 xxxxxxxxxxxxxxxx
ip ospf cost 10
ipv6 address 2001:648:2011:101::2/64
ipv6 enable
ipv6 ospf cost 10
ipv6 flow monitor IPv6_cisco2 input
crypto map vpn
(Note that the "ipv6 ospf authentication" directive is missing from R2, because after experimentation, where we changed the router interface, the directive has not yet been accepted by the router.)
Notes:
1. We have tried disabling STP on vlans 7 and 8, without any change in behavior (normal port status: Forwarding).
2. ARP entries show availability:
R1# sh ip arp | incl 10.201.2
Internet  10.201.2.1              -   0014.a923.1680  ARPA   GigabitEthernet0/0.7
Internet  10.201.2.2              6   dc9f.db00.37fa  ARPA   GigabitEthernet0/0.7
Internet  10.201.2.3              7   dc9f.db00.3712  ARPA   GigabitEthernet0/0.7
Internet  10.201.2.4              0   dc9f.db00.37f8  ARPA   GigabitEthernet0/0.7
Internet  10.201.2.5              0   dc9f.db00.36eb  ARPA   GigabitEthernet0/0.7
R2# sh ip arp | incl 10.201.2.
Internet  10.201.2.1              0   Incomplete      ARPA
Internet  10.201.2.2              7   dc9f.db00.37fa  ARPA   FastEthernet2/0.7
Internet  10.201.2.3              8   dc9f.db00.3712  ARPA   FastEthernet2/0.7
Internet  10.201.2.4              0   dc9f.db00.37f8  ARPA   FastEthernet2/0.7
Internet  10.201.2.5              0   dc9f.db00.36eb  ARPA   FastEthernet2/0.7
Internet  10.201.2.6              -   0014.a923.16b9  ARPA   FastEthernet2/0.7
but we cannot access any of .2 to .5 from either side. For example:
R1#ping 10.201.2.2 source 10.201.2.1
Sending 5, 100-byte ICMP Echos to 10.201.2.2, timeout is 2 seconds:
Packet sent with a source address of 10.201.2.1
Success rate is 0 percent (0/5)
Thanks in advance for any and all help,
Nick
Nikolaos Milas
For completeness, I must explain that finally the problem was the Ub4 device; it was found to seriously malfunction due to a power surge (caused by an electrical storm). The device was flooding the network causing abnormal behavior and all sorts of problems.
So, in essence, the issue was due to hardware failure.
Nick
