Cannot COPY Configuration to Cisco 3650 Switch Using Putty
I have tried for days to copy a saved configuration to my Cisco 3650 switch using putty through the concole port on the switch.  Each time I try every single line loads with this error -  Invalid input detected at '^' marker.  I have restored the default configuration, saved it in a .txt file and attempted to restore it and I still get error -  Invalid input detected at '^' marker.  What am I doing wrong?
Example:
Translating "security-level"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Switch> ip address dhcp setroute
% Invalid input detected at '^' marker.
Switch>!
Switch>interface GigabitEthernet1/2
Switch> nameif inside
Switch> security-level 100
Switch> ip address 192.168.10.1 255.255.255.0
Hi @Richard McCulley
You are on the wrong command prompt.
Example:
Should be:
Switch(config)#interface GigabitEthernet1/2
Please, refers to the following guide:
https://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/configuration/guide/ffun_c/fcf001.html
-If I helped you somehow, please, rate it as useful.-
Example:
Should be:
Thank you so much Flavio, that was exactly the cause.  Your help was very much appreciated.
Richard . . .
