Cannot create more than 507 vlans in N3K-C3048TP-1GE nexus switch!
I'm not able to create more than 507 vlans in nexus layer 2 switch "N3K-C3048TP-1GE". Switch version is
  kickstart image file is: bootflash:/n3000-uk9-kickstart.5.0.3.U2.2b.bin
  kickstart compile time:  11/23/2011 13:00:00 [11/23/2011 21:50:29]
  system image file is:    bootflash:/n3000-uk9.5.0.3.U2.2b.bin"
sh resource vlan
     Resource               Min       Max      Used    Unused     Avail
     vlan                16      4094       512         0      3536
(config-vlan)# vlan 607
ERROR: No VLAN resource available for VLAN creation
sh vlan summary
Number of existing VLANs           : 507
 Number of existing user VLANs     : 507
 Number of existing extended VLANs : 0
Does anybody know what's the reason and how to resolve it? Our network topology is "route-on-a-stick"
Can I go for MST mode with existing topology(route-on-a-stick)?
Md. Mohashin Khan
the configuration limit for the N3K is:
507 VLANs in PVRST mode. 512 VLANs in RPVST mode where 507 are user-defined VLANs, and 4,000 VLANs in MST mode.
So you need to be in MST mode in order to be able to create 4000 VLANs...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/configuration_limits/503_u2_2/b_Nexus3K_Configuration_Limits_for_Cisco_NXOS_Release_503_u2_2.html
