Cannot get second trunk working between 4506-E switches
mhaught1964
Frequent Visitor
Frequent Visitor
Hello All,
Would someone help me troubleshoot a trunking issue?
I am connecting two new 4506s (Sup 6-E in each with X2 converter modules) with SX SFPs over MMF at a distance of about 200 feet.  Each switch has 2 SFPs, connected to ports Gi 1/3 and Gi 1/5
Both sides are configured like this:
interface GigabitEthernet1/3
switchport mode dynamic desirable
logging event link-status
logging event trunk-status
udld port aggressive
spanning-tree bpduguard disable
interface GigabitEthernet1/5
When I issue the sh int trunk command, I get this output:
Port        Mode             Encapsulation  Status        Native vlan
Gi1/3       desirable        802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/3       1-4094
Port        Vlans allowed and active in management domain
Gi1/3       1,142,217,802
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/3       1,142,217,802
As you can see, Gi 1/5 does not come up as a trunk.  The switches are recognizing both SFPs, but I can't get the interface to come up on either switch
on interface Gi 1/5.
I've moved the working connection to other fiber strands, and my fiber is good. I also replaced SFPs and fiber patch cables.
Here's the output from sh interface on one of the "down" interfaces:
as912616s02#sh int gi 1/5
GigabitEthernet1/5 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is 8843.e1b8.a084 (bia 8843.e1b8.a084)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000Base SX
  input flow-control is off, output flow-control is off
  Last input 5d06h, output never, output hang never
  Last clearing of "show interface" counters 00:00:07
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Nothing in the logs.  Any idea what might be preventing the second fiber link from coming up?  Any debug commands that may help? Any help is appreciated!
Thanks!
Mark
5 Replies 5
Mark,
The trunk through Gig1/3 works but not through Gig1/5
This is because the interface is down (or I'm missing something?)
Federico.
Thanks for your response.
Yes, I know the interface is down, but the SFPs, patch cables and fiber are good, so it should have come up like Gi 1/3.
If I move the working fiber from Gi 1/3 to Gi 1/5 on both switches, the trunk comes up on Gi 1/5.  What could be keeping the two switches from allowing a second trunk to come up?  I know spanning tree will block it as park it as a redundant path, but that shouldn't prevent the interface from showing up/up.
But the interface shows as down (not connected)... as not detecting anything on that interface.
If you move the non-working fiber that you have on Gig1/5 to Gig1/3 comes up?
Federico.
Yes, all the fiber is working and all the SFPs are working.  If I take the working trunk (Gi 1/3 to Gi 1/3) and move both sides to Gi 1/5, the trunk comes up again on Gi 1/5.  So, it doesn't appear to be a fiber, SFP or patch cable issue.  The Sup just won't let more than one SFP come up at a time.
The SFP only allows one trunk?
If you have the trunk working on Gig1/5 and you connect the other one to Gig1/3 (Gig1/3 shows down and not coming up)?
Federico.
