cant connect to switch or router using ssh
Husain Khamis
I have 3 branches in my topology, 1 branch works fine, however, I cant connect to the switches and routers in 2 of those branches, I tried doing everything I know, I configured all the switches with vtp, etherchannel for the distribution layer switches, and port security, while the routers are configured with hsrp, ospf and ppp chap. 1 branch doesnt have ssh configured because I thought that if the ping is successful, then ssh should work fine
6 Replies 6
Mark Elsen
        - FYI : Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
badrbelhajja
Could you enclose the picture of your LAB and explain how do you want to connect? From which equipment and to which remote host ?
I need to connect to every switch and router except the Batelco router, the MAN_S7 switch from every pc through ssh except PC24 and PC26
Edit: I realised that the port channel vlan was set as 1 on the working network, which is RIF_S1 and RIF_S2, so I changed it in all the switches that have the portchannel, the manama branch works now, however, I can now ping only 1 router from each branch and the muharraq branch is still not working
badrbelhajja
I've checked the ARP table on the The router MAN-R1 , i see that the mac address of the different vlan99 of the switchs are received on the GigabitEthernet0/0/0 , I think you have a misconfig-vlan-TAG on your switch/Router , i dont have the enable pwd of your LAB to to check your config and have deep troubleshoot:
MAN_R1#show ip arp
Internet 172.16.99.1 27 0000.0C9F.F063 ARPA GigabitEthernet0/0/0.99
Internet 172.16.99.4 5 0001.4232.3B01 ARPA GigabitEthernet0/0/0 <========
Internet 172.16.99.8 5 0007.EC16.E101 ARPA GigabitEthernet0/0/0 <========
Internet 172.16.99.9 21 0001.6316.A701 ARPA GigabitEthernet0/0/0 <========
Compared to RIF Router:
RIF_R1>show ip arp
Internet 192.168.10.225 27 0000.0C9F.F063 ARPA GigabitEthernet0/0/0.99 <========
Internet 192.168.10.228 2 00E0.F9D7.8B01 ARPA GigabitEthernet0/0/0.99 <========
Internet 192.168.10.232 4 00E0.F92E.0501 ARPA GigabitEthernet0/0/0.99 <========
Internet 192.168.10.233 21 000A.F392.7601 ARPA GigabitEthernet0/0/0.99 <========
i invite you to check the vlan config and diffusion on your switches and routers.
I have messed around with the portchannel configuration of MAN_S1 and MAN_S2 by changing the native vlan to 1 instead of 99(which is the management vlan) and now MAN_R1 and every switch works, however MAN_R2 stopped pinging, same thing for RIF_R1 and MUH_R1. While MUH_S1-6 still dont work.
badrbelhajja
Well, i see that you have put Port-channel not on the same switch , you can't do that unless you use a VPC .The spanning-tree dont work correctly with the design you put .
what i advice to you to tshoot your LAB , is deleting all this config , start basi config validate that its working on 1 branch and after add branch by branch , and validate between each steps that your lab works .
