10-08-2013 05:38 AM - edited 03-07-2019 03:54 PM
We want to capture traffic for user wireless traffic, due to some disconnections & ip problems.
Ours is a Wireless service module in cisco 6500 switch.
How do i setup a sniffer on a pc so the wireless user traffic is found. which is the best place to do this for multiple users in the environment.
thanks in advance.
10-08-2013 07:07 AM
The problem is a wireless NIC can't be put into promiscuous mode on Windows machines but you can do it with linux or using airpcap usb adapter for windows.
Alain
10-08-2013 07:09 AM
thanks, but which would be the best place to place the sniffer in to get all these detail packets & what will the configuration look like on the switch side.
10-08-2013 07:43 AM
you shouldn't need anything special on the switch side, just use a machine with a sniffer like wireshark installed and sniff on the wireless NIC in promiscuous mode and use a capture filter to only capture the useful infos.
Alain
