Cat 3560 routing question
forgetoo
The last few days I've been exploring options in getting rid of some old routers accross a wan connections.  I have a cat 3560 to play with and I thought I would try and use the no switchport command test out routing with switch.  I've got some type of route issue and I tried a few things which I thought would fix the issue but had no effect.  I'll post the config and a few commands so you can see what the basic setup is.  I imagine there is a very simple solution I am overlooking.
I have a 10.3.x.x network which is what this switch is in (IP 10.3.3.110)
To test no switchport I used FE0/15 and gave it 10.7.1.1, then plugged in a cat 2960 into that port.
I have a laptop plugged into the 2960 switch which has a ip of 10.7.1.2, and gateway of 10.7.1.1.
The laptop can ping all devices on the lan and even devices across the WAN connected on FE0/5. (10.1.1.1 and 10.2.2.1)
I however cannot ping the default gateway 10.3.3.254 (ASA)
PC (10.7.1.2) <--> cat 2960 <--> (10.7.1.1 no switchport) Cat 3560 <-- X --> ASA (10.3.3.254) <--> Internet
3560 config
ip routing
interface FastEthernet0/1 (ASA here, ASA goes to the ISP)
interface FastEthernet0/13  (routing port created to make a 10.7.x.x lan for this test)
no switchport
ip address 10.7.1.1 255.255.0.0
interface Vlan1
ip address 10.3.3.110 255.255.0.0
router eigrp 1
network 10.3.3.110 0.0.0.0
redistribute connected
ip route 0.0.0.0 0.0.0.0 10.3.3.254
There are a few other things going on in the switch but nothing which should effect this.  That is the basic config more or less.  Below is the routes via eigrp, 10.3.3.254 (ASA) is the default.
#show ip route
Gateway of last resort is 10.3.3.254 to network 0.0.0.0
     10.0.0.0/16 is subnetted, 4 subnets
D       10.2.0.0 [90/28928] via 10.3.3.1, 06:00:16, Vlan1
C       10.3.0.0 is directly connected, Vlan1
D       10.1.0.0 [90/28672] via 10.3.3.1, 06:00:16, Vlan1
C       10.7.0.0 is directly connected, FastEthernet0/13
     192.168.1.0/30 is subnetted, 2 subnets
D       192.168.1.8 [90/3072] via 10.3.3.1, 06:00:16, Vlan1
D       192.168.1.4 [90/3328] via 10.3.3.1, 06:00:16, Vlan1
S*   0.0.0.0/0 [1/0] via 10.3.3.254
#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.3.3.10               0   000e.0c31.f806  ARPA   Vlan1
Internet  10.3.3.3                0   0050.569b.1bc9  ARPA   Vlan1
Internet  10.3.3.1                0   0013.19d3.5340  ARPA   Vlan1
Internet  10.7.1.1                -   001f.9eb3.fc41  ARPA   FastEthernet0/13
Internet  10.7.1.2                0   0025.645c.69cd  ARPA   FastEthernet0/13
Internet  10.3.3.4                0   0050.569b.0b2d  ARPA   Vlan1
Internet  10.3.3.20               7   0022.1912.0c2f  ARPA   Vlan1
Internet  10.3.3.21               0   001c.2359.0b5d  ARPA   Vlan1
Internet  10.3.3.41               0   0014.3887.ef8f  ARPA   Vlan1
Internet  10.3.3.39              24   000e.7f3b.6887  ARPA   Vlan1
Internet  10.3.11.61              0   0021.70f8.dbae  ARPA   Vlan1
Internet  10.3.3.110              -   001f.9eb3.fc40  ARPA   Vlan1
Internet  10.3.3.254              0   0013.c482.5665  ARPA   Vlan1
Here we can see in the arp that it knows about both 10.7.1.2 (PC unable to ping 10.3.3.254) as well as 10.3.3.254 (ASA).
I tried adding in a ip route of 10.7.0.0 255.255.0.0 10.3.3.110 as well as 10.3.3.254.  Neither produced the results I wanted allowing 10.7.1.2 (PC) to ping the ASA (10.3.3.254).
Thoughts?
2 Accepted Solutions
mvsheik123
Level 7
Level 7
As mentioned in your other posting (if i remember it correct), you need routes on the ASA to reach the 10.7.x.x network.
Something like - route 10.7.0.0 255.255.0.0 10.3.3.110 1.
hth
MS
If you don't have a route back the command that mvsheik123 is correct.
route 10.7.0.0 0.0.255.255 10.3.3.110   (The one will be there by default so don't worry about it)
If it's going to the inside interface (which I'm assuming it is)
route inside 10.7.0.0 255.255.0.0 10.3.3.110
Once you enter that command (seeing as if there is no route back to 10.7.0.0 on your ASA) you should
have full bidirectiona IP connectivity.
JohnTylerPearce
Level 7
Level 7
Does the ASA have a route back to 10.7.x.x/16??
Edit:
Also, can I assume that the 10.3.3.254 is the inside interface on the ASA?
mvsheik123
Level 7
Level 7
hth
MS
Yes currently there is no route back from the inside ASA port.  I imagine this will fix it and I will test later this afternoon.  I figured this was a very simple oversight.
edit: I imagine what I will end up doing is setting up eigrp on the inside asa port.
