Cat 3750 stack basic settings
avilt
Level 7
Level 7
Please refer the attached diagram and following is the basic configuration on L3 and L2 switch. Is this configuration sufficient for simple routing?
L3SWITCH:
switch 1 priority 15
switch 2 priority 10
stack-mac persistent timer 0
vtp transparent
no cdp run
ip routing
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
interface vlan10
ip address 10.10.0.1 255.255.0.0
interface vlan20
ip address 10.20.0.1 255.255.0.0
interface gig 1/0/1
switchport mode trunk
switchport trunk allowed vlan 10, 20
switchport nonegotiate
channel-group 5 mode active
interface gig 1/1/1
L2SWITCH:
vtp transparent
no cdp run
interface range gig 1/0/1 - 2
2 Accepted Solutions
JohnTylerPearce
Level 11
Level 11
Everything looks good, I just have a few questions. Since the L2 switch is L2, do you have 'ip default-gateway x.x.x.x' configured and an IP address for managability? Other than than, basic network connectivity looks fine. I didn't see a default route either on the 3750 stack, but that's up to you. If they don't require internet access or only need to have traffic going between those two networks you should be fine. Also, depending on how you want to do ip address assignment via DHCP or static, for  DHCP you will want to setup some dhcp pools and you might need some helper addresses depending on where yo uput it.
stack-mac persistent timer 0 command on the stack, do I need to define any special settings?>
No, the stack-mac persistent timer 0 command will reduce your OSPF convergence time significantly in case of master switch failure.
6 Replies 6
JohnTylerPearce
Level 11
Level 11
I will take care of default gateway and management IP on L2 switch and DHCP on L3 switch.
On L3 switch the routes will be learnt by OSPF. Please refer the attached diagram, for OSPF other than defining stack-mac persistent timer 0 command on the stack, do I need to define any special settings?
I have added the following commands on L2/L3 switches as part of hardening. Is it safe to add these commands? Also is there any specific application for auditing the Cisco switches, example for routers we can use Cisco Configurational Professional.
spanning-tree UplinkFast
scheduler interval 500
no udld enable
ip tcp synwait-time 10
errdisable recovery cause bpduguard
errdisable recovery interval 400
Interface Level:
spanning-tree bpduguard enable
I really don't understand why people would enable BPDU guard and also have these lines.
If you want your switch to recover BPDU guard-caused error disable, wouldn't it just make sense to disable BPDU guard instead?
In the above scenario, I have connected both routers to Master switch (just for a test) and powered off the Member switch. Now I am seeing the following logs on both routers. I have defined stack-mac persistent timer 0
on the Stack. Why does this log appear?
RTR1:
000041: *Feb 14 15:34:46.716 JST: %OSPF-5-ADJCHG: Process 65182, Nbr 171.16.0.25
1 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
RTR2:
000032: *Feb 14 15:26:31.391 JST: %OSPF-5-ADJCHG: Process 65182, Nbr 171.16.0.25
