Cat 3850 intervlan license
Anwar Safian
Hi expert
I would like to know what license type for Cat 3850(Lan lite, Lan base, ip base, ip service) for enable intervlan routing?
luis_cordova
Hola @Anwar Safian ,
According to this link, with the LanBase license you can execute routing commands, such as static routes, so that with that license you should being able to do InterVlan:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
High-performance IP routing
The Cisco Express Forwarding hardware routing architecture delivers extremely high-performance IP routing in the Cisco Catalyst 3850 Series Switches:
●   IP unicast routing protocols (static, Routing Information Protocol Version 1 [RIPv1], and RIPv2, RIPng, Enhanced Interior Gateway Routing Protocol [EIGRP] stub) are supported for small-network routing applications with the IP Base feature set. Limited static routing with the LAN Base feature set. Equal-cost routing facilitates Layer 3 load balancing and redundancy across the stack.
I leave this picture with the functions of the licenses:
luis_cordova
