ā03-18-2012 01:27 AM - edited ā03-07-2019 05:37 AM
Hi Guys,
We have a VSS environment with two Cisco 6509-Es.
IOS image:s72033-ipservicesk9_wan-mz.122-33.SXI5
when I switch on or reload the Core switches(VSS), I find a Minor Error in the "Show module switch all" command.
I also did a "show diagnostic result switch 1 module 5"
Switch 1 Module 5: Supervisor Engine 720 10GE (Active) SerialNo : SAL1521E035
Overall Diagnostic Result for Switch 1 Module 5 : MINOR ERROR
Diagnostic level at card bootup: complete
Test results: (. = Pass, F = Fail, U = Untested)
45) TestVslLocalLoopback:
Port 1 2 3 4 5
U U U . F
This issue temporarily relieves when reseating the X2 module, but reappears after reloading the switch.
Any comments/Suggestions are highly appreciated.
Siby.
ā03-18-2012 01:42 AM
RMA the module. If it's re-occurs then rest assured, something sinister is happening.
ā03-18-2012 04:10 AM
Many thanks for the reply..
When I reload some times the Minor error appears and sometimes not.
Still do you think this could be a Hardware issue?
ā03-18-2012 08:30 AM
If the issue disappears when you reseat the X2 module, then replace the X2 module first. I am assuming you are referring to the X2 modules on the Sup right?
ā03-20-2012 06:10 AM
Hi Reza,
Thanks for the reply,
Let me re-create the problem and confirm this.
ā03-18-2012 02:08 PM
Yes I do.
