Cat5e supports 10/100/1000 speed or not
engmgaengmga
 I'm having a network consisting of some cisco switches different models managed and unmanaged but all are 10/100/1000 gigabit switches the links between the switches and each other are Cat6 but the links between the switches and the pcs are cat5e premium line European Authorized IEEE standardmy question isdoes the cat5e supports the speed of the switches 10/100/1000 between the pcs and the switches or not ?
Julio E. Moisa
Cat 5e is supported by 1000 Base T specification, you can connect a PC to a Giga switchport and it will work on giga speed.
Please check this link:
http://www.l-com.com/can-cat-5e-cabling-be-used-in-gigabit-ethernet-applications
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
As Julio already noted, cat5e supports gig.
You might find this web page (http://www.kit-communications.com/FAQCat5evsCat6.htm) of interest because cat5e might even support 10g up to 45m.
