Cat6500 VRF Lite question
jcshen
Community Member
How do I configure a vrf instance in a 6K and using L3 SVI in the same chassis as the default gateway ?
Topology :
ServerA-(vlan10:VRF:vlan20)--(SVIvlan30)---ServerB
thanks
James
Collin Clark
I'm not an expert on VRF's but I believe you would use the global command to use the global routing table.
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_mltvrf_slct_pbr.html
Hope that helps
