Hello Friend,
No You dont have DFC's in the attached BOM, not in any switch option. You need to have DFC-3B on your line cards for distributing CEF i.e. D-CEF
The part number is : WS-F6700-DFC3B
You need 4 DFC's for Switch option 1, one each for 6748-GE-TX and 6724-SFP's.
You need 4 DFC's for Switch option 2, one each for 6748-GE-TX
You need 4 DFC's for Test switch option, one each for 6748-GE-TX
Switch 3 doesnot have any fabric enabled cards, it has only the classic cards so it doesnt require any DFC's.
HTH,please rate if it does.
-amit singh
