Catalyst 1000 SVIs?
I'm looking to deploy a stack of catalyst 1000 series switches, specifically the 1000-48P-4G-L switch.
I would like the stack act as the gateways for the VLANs, and do inter-vlan routing.
How many SVIs are supported? I've tried doing some research, but an getting conflicting information.
Thanks.
7 Replies 7
Leo Laohoo
256 active VLANs (Data Sheet).
Mohsin Alam
Cisco Catalyst 1000 Series switches support unique default templates that cannot be modified.
The switches support the following level of features for 64 Switch
Virtual Interface (SVI) and 64 Virtual LANs (VLANs):
●      Number of IPv4 multicast groups: 1024
●      Number of unicast MAC addresses: 16,000
●      Number of IPv4/IPv6/MAC access control entries: 600(384/256 for FE SKU)
## Make sure to mark post as helpful, If it resolved your issue. ##
Luis Perez
Could anyone confirm if intervlan routing is supported for Catalyst1000? @Mohsin Alam
As far as I am aware, Catalyst 1000 is purely a Layer 2 switch.
Catalyst 9k series supports Layer 3 functionality.
I don't think so.
The 1000 series has advanced l2 functionality, so l3 routing and SVIs.
a50573329
is the Series 1000 support static routing and intervlan routing ?
