Catalyst 2940 Resetting (Lost PW)
sendalot7
Trying ot reset Catalyst 2940 after losing password.
I pressed the "mode" button upon power-on to start the resetting.
After that, I tried commands like flash_init and boot, etc.
But the old config is still there.
How do I start fresh?
Thanks.
devils_advocate
Level 7
Level 7
Have you followed the guide?
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Once you are in ROMMON, you have to initialise the flash and rename the config file so the switch boots without a config. You can then either change the password or start again.
devils_advocate
Level 7
Level 7
Yes I've referred to Cisco manuals but following it is difficult. haha..
Rename using "rename?"  of the start config?
Thanks!
I don't understand, if you simply follow the step by step in the article above it should work?
Yea, I'll try again when I get home.
Again, thanks for the link.
UPDATE: Turns out the way I did was already working. haha.  Thank you all!
