Catalyst 2950 default IP Address?
nwaslynchuk
I have a site with about 8 Catalyst 2950s, all connnected with fibre. My problem is that I don't know if they have been enabled with an IP address. I have used the Network Assistant and searched my subnet without luck. It may be on another subnet. I don't have a rollover cable handy to check a box through the console.
Does anyone know if the Catalyst 2950 has a default IP address?
Does anyone have any other ideas which might help me?
Jon Marshall
No they don't come with a default IP.
If CDP is enabled you could try "sh cdp neigh det" on each switch.
Jon
Leo Laohoo
The only way "in" is using the switch clustering.
Creating and Managing Clusters
https://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_xu/scg/kiclust.html
