Catalyst 2960 PoE-24 not working
Arun Jayapalan
Hi All,
My C-2960 PoE-24 switch is not working. when i power on the switch , all the LED's ( SYST,RPS,STAT,DUPLX,SPEED,PoE) are in amber color.
When i connect devices to the  fast ethernet port the port led is also in amber color. When i connect this switch using console port and accessing via putty its shows a blank page.
Here  am attaching the picture of Switch LED.
Please help me to sort out this issue.
Collin Clark
Sounds like a major hardware fault. If you have maintenance, open a TAC case for replacement.
Thank you....
so there is a master and backup switches in the stack , it shouldn't matter whether its in master or backup as logically its 1 unit 1 switch when bundled together , I would definitely replace cabling etc as its showing as a layer 1 issue ,  and also compare the working no working ios versions
the master will be the switch that has its master LED lit or if you go to the command line and do
show switch it will show you
#sh switch
Switch/Stack Mac Address : c414.3c4f.cd80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master c414.3c4f.cd80     15     1       Ready
 2       Member 3c0e.237b.5f00     1      1       Ready
