Catalyst 2960-X Stack Ring stats
Michael Grann
Level 2
Level 2
Hello, does anyone know the CLI's to look at the statistics/performance of the Catalyst 2960's stack ring or backplane? I'm interested to find out just how much oversubscribed the stack is and if it's time to upgrade the hardware (e.g. Ingress drops).
Thank you.
-MG
Reza Sharifi
As far as I know, there is no commands showing statistics/performance for stacking cable.
Using the cli usually you can see:
stack-bandwidth,  stack-ports  and stack-ring
Mark Malone
hi not sure if you can get that visible on stack-ring , there's not many commands for stack-ring or ports on the 29s , how many switches are in the stack
sh switch stack-ring  activity detail
sh switch stack-ports summary
Hello
Just like to add another command to see statistics Rx/TX statistics per stack port
sh controllers ethernet-controller stack port x
res
Paul
Edited-  wrong post- ---apologies..
Kind Regards
Paul
