Catalyst 3560 <-> 3560 Bandwidth / Error Issues
caymanport
We have a pair of Cisco Catalyst 3560 switches that are connected using a leased (from the local telco) gigabit single-mode fiber.  It is about 2 miles line of sight between the switches but I don't know how long the actual cable run is.  This line is receiving very low bandwidth and looking at the link stats, one side is showing an ever increasing number of errors:
First switch:
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0014.1c9b.d101 (bia 0014.1c9b.d101)
  Description: HDSwitch SM-Fiber
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 246/255, txload 3/255, rxload 1/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:19:25
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7508000 bits/sec, 1793 packets/sec
  5 minute output rate 12090000 bits/sec, 2124 packets/sec
     2199784 packets input, 1041317090 bytes, 0 no buffer
     Received 11319 broadcasts (8249 multicasts)
     166031 input errors, 1679 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 8249 multicast, 0 pause input
     2632177 packets output, 1948955584 bytes, 0 underruns
Other end of link on 2nd switch:
  Hardware is Gigabit Ethernet, address is 0014.1c9b.cc01 (bia 0014.1c9b.cc01)
  Description: CDCSwitch SM-Fiber
     reliability 255/255, txload 1/255, rxload 3/255
  Keepalive not set
  Last input 00:00:01, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:19:22
  5 minute input rate 12066000 bits/sec, 2126 packets/sec
  5 minute output rate 7508000 bits/sec, 1933 packets/sec
     2621228 packets input, 1938324356 bytes, 0 no buffer
     Received 17935 broadcasts (7536 multicasts)
     0 watchdog, 7536 multicast, 0 pause input
     2353278 packets output, 1039344313 bytes, 0 underruns
As you can see, errors are only appearing on one side of the link and the reliability is down to 246/255.  Is there anyway to tell if this is due to the leased line itself, the SFPs or the switch?
Thanks!
5 Replies 5
Zach S
A good first step when you get errors that only affect one side of a fiber link is to clean your fiber on that side. You can pick up an isopropyl alcohol wipe for fiber cleaning at little cost.
http://www.cisco.com/c/en/us/support/docs/optical/synchronous-digital-hierarchy-sdh/51834-cleanfiber2.html
I will try this on Monday. Thanks.
Hello
Have you changed the cabling- if not please do so.
clear the counters again and see it these error return
res
paul
Kind Regards
Paul
Which cabling are you referring to?  I can change the patch cable between the fiber panel and the switch on either end (or both) but that's about it.  The rest is owned by the local telco.
caymanport
Well, I swapped SFPs and what cables I could and still having problems so it looks like the issue is with the telco.  Thanks for everyone who assisted.
