Catalyst 3560
elautomation
I am trying to use the remote PS for the Catalyst 3560.  I have not been able to locate the harness to make this connection.  Is the harness normally provided with the switch or purchased seperate.  I need to purchase if not provided.  Could you send me a link to purchase harness.  The manual says it is 120VAC and 12VDC capable.
Amit Singh
Hi Steve,
Are you referring to Cisco Redundant Power supply for 3560, to provide redundant power to the switch? If yes, you need CAB-RPS2300= to connect the 3560 switch to it. Please see the datasheet below :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7148/ps7130/product_data_sheet0900aecd805bbef6.html
HTH,
-amit singh
Amit Singh
Hi Steve,
HTH,
-amit singh
