One Site not reachable
townofnewmarket
This is so strange, I can't figure it out, maybe somene out there can help.
Clients are largely Windows XP SP3, but with some Linux and Macintosh thrown in.
Switches are 3560s POE, with one 3560G.  Firewall is a PIX515-E.  We have some static IP addresses, so we have a small SMC router from Comcast in the data closet too.
So here's what's happening:
I try to go to www.trythissite.com, and it times out.  Pinging it resolves it to an IP, but the pings are not answered.  Virtually every other website out there is fine, we get right to them.  Hmm...using the DNS handed me by windows.  Let me use a few well known public DNS addys (8.8.8.8, 4.2.2.1, etc.)  Same results, so doesn't seem to be a DNS issue.
Doing a traceroute to the host name only gets me one hop, the default gateway (Cisco 3560G), everything else times out.
Take a PC, plug it into the SMC router, and we get to www.trythissite.com everytime.  So it sure seems to be something on my end.  There is nothing in the PIX configuration referencing the IP or its subnet, so the PIX would not appear to be dumping the requests (though I don't know enough of the PIX and how to confirm that).
The PC goes to a 3560G, the PIX does NAT for us, and out we go to the real world (well we plug into the SMC router on the way, but that doesn't seem to be a block).  Both a Linux client and a Mac client on the same switch have the same failure (so it's not web filtering, as those clients don't web filter).
Appreciate ANY help!  Wouldn't you know, it's a fairly important website, lol!
We can check if the problem is with the PIX or not.
i.e
access-list capin permit ip host x.x.x.x host y.y.y.y
access-list capin permit ip host y.y.y.y host x.x.x.x
capture capin access-list capin interface inside
access-list capout permit ip host z.z.z.z host y.y.y.y
access-list capout permit ip host y.y.y.y host z.z.z.z
capture capout access-list capout interface outside
The first capture is applied to the inside interface:
x.x.x.x --> Real IP of the computer or host trying to reach the website
y.y.y.y --> Real IP of the website that you're trying to reach
The second capture is applied to the outside interface:
z.z.z.z --> NATed IP for the computer
Also, just curious what is the result of a packet tracer?
packet-tracer input inside x.x.x.x 1025 y.y.y.y 80 detail
Federico.
12 Replies 12
If you connect directly to the SMC router it works.
The problem is if you pass through the PIX correct?
You said that when you do a lookup for the domain name you get an IP (so DNS is not the problem).
Can you open a browser and get to the website typing the IP instead than the name?  http://1.1.1.1
Is there any filtering configuration on the PIX that might be causing this problem?
i.e
The PIX can filter acitveX, java on destination traffic to port 80 on the Internet.
Federico.
Federico,
yes you understand it correctly.  If we go through the PIX, we don't get there.  Plug directly into the SMC, (or connect from home) and we get there just fine.  The PIX was filtering java and ActiveX, so I removed that.  Still no change in behavior.
Opening a web browser and pointing to the IP fails as well, (using Firefox) the error is "The connection to the server was reset while the page was loading.  The network link was interrupted while negotiating a connection. Please try again."  With IE,it fails as well, and suggests DNS problems, site down externally, network issues, etc.
Very strange!
i.e
Federico.
I don't have packet-trace available as a command on my PIX.  Must be an old release.
Once I add the lines you gave me to the config, here's the output:
show capture capin
0 packet captured
0 packet shown
show capture capout
16 packets captured
01:53:39.995996 100.101.102.103.20467 > 67.68.69.70.53:  udp 39
01:53:43.172461 100.101.102.103.20465 > 67.68.69.70.53:  udp 39
01:53:51.171728 100.101.102.103.20483 > 67.68.69.70.53:  udp 39
01:53:51.171774 100.101.102.103.20485 > 67.68.69.70.53:  udp 39
01:55:28.163458 100.101.102.103.20731 > 67.68.69.70.53:  udp 35
01:55:28.163565 100.101.102.103.20733 > 67.68.69.70.53:  udp 35
01:55:32.330991 100.101.102.103.20743 > 67.68.69.70.53:  udp 35
01:55:36.162802 100.101.102.103.20741 > 67.68.69.70.53:  udp 35
01:55:40.585861 100.101.102.103.20766 > 67.68.69.70.53:  udp 39
01:55:44.161994 100.101.102.103.20768 > 67.68.69.70.53:  udp 39
01:55:48.181982 100.101.102.103.20797 > 67.68.69.70.53:  udp 39
01:55:52.161307 100.101.102.103.20799 > 67.68.69.70.53:  udp 39
01:57:49.149238 100.101.102.103.21118 > 67.68.69.70.53:  udp 39
01:57:53.150703 100.101.102.103.21116 > 67.68.69.70.53:  udp 39
01:58:01.150001 100.101.102.103.21124 > 67.68.69.70.53:  udp 39
01:58:01.150047 100.101.102.103.21126 > 67.68.69.70.53:  udp 39
16 packets shown
101.101.102.103 is the outside IP of the PIX.
67.68.69.70 is the IP of the host that has the website.
Does this tell us anything?   These commands are new to me!  Thanks a bunch!
Some recent traceroute information:
Windows Client (internal going through PIX):
tracert [ip addr of webhost]
Goes about 14 hops, gets all the way to this host, but never the final host:
14    47 ms    50 ms    46 ms  lw-dc3-dist7-po5.rtr.liquidweb.com [69.167.128.129]
15     *        *        *     Request timed out.
16     *        *        *     Request timed out.
17     *        *        *     Request timed out.
18     *        *        *     Request timed out.
19     *        *        *     Request timed out.
20     *        *        *     Request timed out.
21     *        *        *     Request timed out.
22     *        *        *     Request timed out.
23     *        *        *     Request timed out.
Linux Box attached to SMC router:
traceroute [ip addr of webhost]
13  lw-dc3-dist7-po5.rtr.liquidweb.com (69.167.128.129)  46.081 ms  46.923 ms  43.747 ms
14  host.dotnotme.com (59.137.150.188)  50.641 ms  47.774 ms  49.275 ms
So again, if we're outside the corp net,we make it all the way.  Inside, we almost get there, we die on the very last step.
Does that help any??
Do you have any access-list applied to the vlan on the switch before the PIX firewall. Please check - thanks.
You're right the packet-tracer is not available.
The idea is to send traffic and capture the traffic.
https://1.1.1.1/capture/capin/pcap
https://1.1.1.1/capture/capout/pcap
The idea is to get the captures and open them with wireshark (wireshark.org)
Change 1.1.1.1 for the IP of the ASA.
You must enable HTTP.
Federico.
I did
http server enable
but all http(s) requests to the PIX fail with a timeout.  Do I need to set anything else for the http to show me what it's getting for packets?  Anyway we can dump it to a tftp server?
Besides enabling http:
http 0 0 inside
To allow every IP from the inside.
If still does not work, need to generate the RSA keys:
name NAME
domain-name DOMAIN NAME
crypto key generate rsa
Federico.
The http 0 0 inside went fine.
Generating RSA keys was a little more difficult,
name NAME doesn't work for me.
domain-name DOMAIN worked
crypto key generate rsa didn't work, so I used
ca generate rsa key 512
and got this:
% You already have RSA keys defined for xxx.yyy.com.
% Please remove the keys by issuing ca zeroize rsa command
%   before generating RSA keys again.
Still can't connect. I can dump to the console, maybe I could cut and paste it into a packet capture program
I sure do appreciate all the help you've given so far Federico!  Thank you!!!!!
I don't want to be troubleshooting something that is not the original problem but if we can get the captures via HTTP that will help to the original issue.
So,
When you open a browser and type https://1.1.1.1 (changing 1.1.1.1 for the inside IP of the PIX what do you get)?
I am assuming that you can PING that address and that you're on the internal network.
In order to get the HTTP service working on the PIX:
- http server enable
- http 0 0 inside
- hostname    --> this should be the hostname of the PIX
- domain-name a domain for the PIX (could be cisco.com for example)
- username test password test123 privi 15
- aaa authentication http console LOCAL
The crypto keys are already in place.
Try accesing the PIX via web and if it does not work let me know the IP of the PIX that you're trying to connect to and the IP that you're coming from.
Federico.
Federico, thanks so much for sticking with me on this one!
So now I have the capture ins and outs.  I have opened them with wireshark, but they don't mean a whole lot to me!
Can I mail you the captures or something?
Thanks.
