Catalyst 3560G-48TS-E or 48TS-S?
Peter Gray
Our customer needs a Catalyst 3560G.  This switch will need some basic routing function (OSPF).  Can we get away with using the standard disk image (48TS-S)?  Or do we need the enhanced image (48TS-E)?  Please share your input.
lgijssel
Level 9
Level 9
Hi Peter,
Standard image only includes RIP and static routing.
So you will need the (more expensive) E-version to run ospf.
Leo
lgijssel
Level 9
Level 9
Hi Peter,
Leo
Daniel Laden
Level 4
Level 4
It looks like with the IOS 12.2.SEE you will need E.  With 15.0, it looks like you can use S.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
WS-C3560G-48TS-S
• 48 Ethernet 10/100/1000 ports and 4 SFP-based Gigabit Ethernet ports
• 1RU fixed-configuration, multilayer switch
• Enterprise-class intelligent services delivered to the network edge
•  IP Base software feature set (IPB)    <<<<<<<<<<<<<<<<<<<<<<<<<
WS-C3560G-48TS-E
•  IP Services software feature set (IPS)   <<<<<<<<<<<<<<<<<<<<<<<<<
• Provides full IPv6 dynamic routing
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by Software
select the drop downs for the 3560 IP BASE
click compare images
select the same drop downs but feature set ip services
Common Features in Both Images
OSPF
OSPF for Routed Access
OSPF Forwarding Address Suppression in Translated Type-5 LSAs
OSPF Inbound Filtering using Route Maps with a Distribute List
OSPF Not-So-Stubby Areas (NSSA)
OSPF Support for Multi-VRF on CE Routers
OSPFv3 Graceful Restart
Leo Laohoo
What version of OSPF?  If memory serves me right, OSPFv1 is supported on the IP Base feature set starting from 12.2(55)SE.
This will also depend if your appliance have 32 mb flash or not since 15.0 requires a minimum of 32 mb flash.  Otherwise, you're stuck with 12.2(55)SE.
