Catalyst 3650
eunicemeukieje
Frequent Visitor
Frequent Visitor
Dear All,
After power failure in our Network Closed, our Cisco Catalyst 3650 48 PoE+ 4X10G restarted normally but is showing error (see attached file).
furthermore i am able to access the switch console and enter command but all the led on the ports are amber (even with nothing connected to them.
do someone faced such a case?if yes any idea on how to sort it out?will appreciate your assistance.
Stephane
Reza Sharifi
The power failure probably caused a software crash. Is there a crash file written on the flash? You may want to reload the switch from the cli and see if everything gets back to normal, if not you may have to load a new version of the IOS.
Hi Reza,
how can i know that there is a crash file in the flash (see attached the flash content)i had reload the switch sevral time but same result.
however i have a version of the IOS imagewould appreciate your assistance to load it.
regards,
Stephane
Philip D'Ath
Meraki Community All-Star
Have you tried powering the switch down, waiting, and then powering it back up again?
Hi Philip,
I have  tried powering the switch down, waiting for 10minutes  and then powering it back up again but no change.
thanks,
Stephane
