Catalyst 3750 InterVlan routing Performance
egemen1981
We are using port based vlan configuration, for every building we are using one vlan. Each Building contains approximetely  100 employees. But the routing performance between vlans are poor. Because of performance problem, ms outlook is repeatedly giving "connection has lost" , "connection restored" messages.
How can i increase the routing performance?
Regards.
ranraju
Well this definitely requires some troubleshooting. I think you should open a TAC case and investigate this issue further. Have you done ping tests on your network, did you see ping drops or high latency in the pings? Is this is new setup. Or is it a working one, but now you are seeing a performance degradation?
Ranganath
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Might not be the 3750s as where I'm at we see the same issue with MS Outlook/Exchange and we're running across 6500s.  What else "shows" poor network performance?
Everything was working fine, or we think so and we did not see any warning from exchange server. I am also monitoring the traffic, there is not so much traffic on vlan interface.
hi egemen,
do you also have clients located in the same vlan as the exchange server? if yes, do they also show the same problem?
what other traffic is also routed via this c3750?
as ranraju said before it would be a good thing to test the connectivity and the latency with pings.
regards,
florian
