0There are two stacks of WS-c3750X-24T-S.
IOS c3750e-ipbasek9-mz.150-2.SE2.bin.
First question is Is it possible to build IPSec tunnel between stacks.
I read https://supportforums.cisco.com/thread/263171 about 3750
but repeat the question just in case, because I've got 3750-X.
And the second one is sequent to previous. If it's impossible, then what is IPSec on 3750-X for? Does it work at all?
I can't create an IPSec profile, because of an absence of encryption support by hardware.
ho_c3750_dmz(config)#crypto ipsec transform-set IntraLink esp-sha-hmac esp-3des
Transform IntraLink disabled because esp-3des esp-sha-hmac is not supported by encryption hardware
And it is the same answer on any of combination.
