Catalyst 3850 - garbled SSHv2 CLI output
Robert Saurer
Has anyone seen this before? (screenshot)
We use IOS XE 3.3.5.
Do you think it's a switch problem or a SecureCRT problem?
Reza Sharifi
Try using a different terminal emulator like putty (it is free) and see if you have the same issue.
Do you have the issue with Telnet?
TheRealBecks
It seems to be a translation (coding) error, so maybe your terminal software on your pc uses the wrong coding? Because the showed words are everytime the same wrong symbols on your display. As Reza Sharifi already said, try using Putty for Windows. There it's possible to configure the coding language and connect via Telnet and SSH so you can test different settings.
