Catalyst 4500R+E composition
Maxim Sergeev
Community Member
Hi!
I collected structure switch in Cisco Dynamic Configuration Tool. After clicking "Check Configuration" appeared the following error:  "When both Primary and Redundant SUP7 Supervisors are ordered with  Memory, then the memory ordered must be equal and ordered on both  Supervisors"
What does this error mean?
I did not choose the option of additional memory.
Here is the configuration from Cisco Dynamic Configuration Tool:
WS-C4507R + E
CAB-CON-C4K-RJ45
S45U-32-1502SG
WS-X45-SUP7-E / 2
WS-X45-SUP7-E
WS-X4624-SFP-E
CAB-CEE77-C15-EU
PWR-C45-1000AC / 2
PWR-C45-1000AC
Maxim Sergeev
Community Member
I crated case in Cisco Virtual Engineering- Partner Help program.
Employee Cisco Virtual Engineering-Partner Helpline said that "The  Dynamic Configuration Tool (DCT) is outdated. We recommend using the  new Cisco Commerce Workspace (CCW) which you will find at:  https://cisco-apps.cisco.com/cisco / psn / commerce "
I gathered the necessary configuration switch, and this time with no errors.
