08-20-2015 07:26 AM - edited 03-08-2019 01:26 AM
I want to know the difference between these commands:
boot system flash sup-bootdisk:XXXXX
boot system sup-bootdisk:XXXXXX
Both work well but what's the "flash" setting adds?
Thanks for your help.
Best regards
Zineb
Solved! Go to Solution.
08-20-2015 05:59 PM
There is no difference. The 6500 series has flash and that is why you see the word "flash" in the boot statement. On the new 6800 its not called flash anymore. It is called "bootdisk".
08-20-2015 05:59 PM
