Catalyst 6506 crash!!!
nunoscosta
Hi guys,
Can you help me understand this carsh info?
show version show this line:
System returned to ROM by s/w reset at 00:09:09 UTC Sat Jan 1 2000 (SP by watchdog NMI at PC 0xBFC262B0, address 0x0)
Partial CrashInfo:
Writing crashinfo to bootflash:crashinfo_20100625-13480460).
43w0d: %C6K_PLATFORM-2-PEER_RESET: RP is being reset by the SP
%Software-forced reload
Breakpoint exception, CPU signal 23, PC = 0x41C1BC4C
-Traceback= 41C1BC4C 41C19B98 41709970 4170AD2C 41967170 419672C8 41C0E66C
$0 : 00000000, AT : 42DB0000, v0 : 44740000, v1 : 43300000
a0 : 46E6F29C, a1 : 00008100, a2 : 00000000, a3 : 42B00000
t0 : 41C0E758, t1 : 34008101, t2 : 41C0E780, t3 : FFFF00FF
t4 : 41C0E758, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 42D70000, s2 : 00000000, s3 : 42D40000
s4 : 42D40000, s5 : 42D40000, s6 : 42860000, s7 : 42860000
t8 : 5001025C, t9 : 00000008, k0 : 00000000, k1 : 00000000
gp : 42DB7450, sp : 50010340, s8 : 42860000, ra : 41C19B98
EPC  : 41C1BC4C, ErrorEPC : 050436F9, SREG     : 34008103
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 00000000
DATA_START : 0x42AB5B30
Cause 00000824 (Code 0x9): Breakpoint exception
========= Start of Crashinfo Collection (14:48:04 WEST Fri Jun 25 2010) ========
For image:
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF16, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Tue 03-Mar-09 23:43 by kellythw
How can i debug this file?
NC
Ganesh Hariharan
Hi guys,
Partial CrashInfo:
For image:
NC
Hi NC,
Check out the below bug details for the above logs
CSCsk70087 Bug Details
Sup720 TLB exception created by fill_earl_vlan_stats_hdr
The RP crashinfo reports the following:
Breakpoint exception, CPU signal 23, PC = 0x41CDA8E4
Since the crash is triggered by the SP, the crashinfo in sup-bootflash logged the following:
%ALIGN-1-FATAL: Illegal access to a low address
addr=0x0, pc=0x40362F24, ra=0x40363000, sp=0x43A179F8
TLB (store) exception, CPU signal 10, PC = 0x40362F24
This problem is seen at a customer site.
Hw and Sw version info as follows:
WS-SUP720-3B running 12.2(18)SXF2
Trigger for crash: Unknown
Workaround: None
Fixed in version for the above bug :-
12.2(33)SRC
12.2(32.8.11)SX125
12.2(18.11.5)SXF
12.2(18)SXF12
12.2(32.8.11)SR106
12.2(33.2.9)SRB
12.2(33)SXH1
12.2(18)ZYA
12.2(33)SRB3
12.2(32.8.99a)SR133
12.2(32.8.11)XJC153.1
12.2(32.8.1)YCA172.24
12.2(32.8.1)YCA206.18
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
Hi guys,
Partial CrashInfo:
For image:
NC
Hi NC,
Workaround: None
12.2(33)SRC
12.2(32.8.11)SX125
12.2(18.11.5)SXF
12.2(18)SXF12
12.2(32.8.11)SR106
12.2(33.2.9)SRB
12.2(33)SXH1
12.2(18)ZYA
12.2(33)SRB3
12.2(32.8.99a)SR133
Hope to Help !!
Ganesh.H
