Catalyst 65xx Sup Engine upgrade question
floridomd
We have a bunch of old stuff on the network than needs to be replaced or upgraded.  Some of our 6500s are using the SUP720-3B, and we're considering upgrading to the VS-2T-10G.    The white paper indicates that the 2T SUP is backwards compatible for the 67xx line cards, but then it mentions swapping out daughter cards.  So my question is as follows:
Is the 2T Sup Engine backwards compatible with the 67xx line cards the way it ships, or do I need to purchase an additional daughter card to make sure that it will function with the existing 67xx line cards?
In case it matters, here is a listing of some of the line cards:
WS-X6748-GE-TX CEF720 w/WS-F6700-CFC
WS-X6748-SFP CEF720 w/WS-F6700-CFC
WS-X6724-SFP CEF720 w/WS-F6700-CFC
Reza Sharifi
According to the Q&A, it is compatible:
Q. I have Cisco 6700 Series line cards today with Centralized Forwarding Cards (CFCs). Are these line cards supported in a Cisco Supervisor Engine 2T system?
A. A Cisco Supervisor Engine 2T system will support all Cisco 6700 Series line cards with CFCs.
Link:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-6500-series-supervisor-engine-2t/qa_c67-648478.html
There is also an option to upgrade CFC to DFC.
Mark Malone
see below it comes with daughter card MSFC5 and my output from my VSS is running those cards with that daughter card
CORE#sh inventory | i MSF
NAME: "Chassis 1 msfc sub-module of 5", DESCR: "Chassis 1 VS-F6K-MSFC5 CPU Daughterboard Rev. 1.4"
PID: VS-F6K-MSFC5      ,                     VID:    ,
NAME: "Chassis 2 msfc sub-module of 5", DESCR: "Chassis 2 VS-F6K-MSFC5 CPU Daughterboard Rev. 1.4"
CORE#SH MOD
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/02superv.html
Supervisor Engine 720 Product Numbers
Description
VS-S2T-10G
The VS-S2T-10G is shipped with a factory-installed PFC4 daughter card (VS-F6K-PFC4) and a factory-installed MSFC5 daughter card (VS-F6K-MSFC5). There are five uplink ports: two 10GBASE-X Ethernet ports that require the installation of X2 transceivers and three 1000BASE-X Ethernet ports that require SFP transceivers.
VS-S2T-10G-XL
The VS-S2T-10G-XL is shipped with a factory-installed PFC4XL daughter card (VS-F6K-PFC4XL) and a factory-installed MSFC5 daughter card (VS-F6K-MSFC5). There are five uplink ports: two 10GBASE-X Ethernet ports that require the installation of X2 transceivers and three 1000BASE-X Ethernet ports that require SFP transceivers.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The sup2T will work with 67xx cards with CFCs or DFC4s.  The one problem card is the 6708, which has a non-changable DFC3.
