Catalyst 7600 SUP-32
patcbr600
Hi all,
I have several Cisco 7609 with dual sup-32 installed, and from times to times when the switch suffer a power fail, the standby sup never come up, stays in rmon, the config/ios/bootvar are sync between the two sup-32. The only way to get the sup up and running is to manually perform a boot in rmon.
Does anyone has a similar problem ?
Yudong Wu
Level 7
Level 7
can you check if your register number set correctly on both MSFC and SP.
jbrenesj
Level 3
Level 3
Yes, use a "remote command switch show ver" and check the config-register of the SP
For the standby then you need to do a failover (or wait) and then check it out
