Catalyst 9200L Power Controller reports power Imax error detected
stuart.pannell
Level 3
Level 3
We are currently swapping out a number of old 3750 V2's for 9200L switches and have come across the following error a number of times on various switches: -
-3-CONTROLLER_PORT_%ILPOWERERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
Different types of devices have caused this from 3rd party door controllers to Cisco 9115ax Wireless AP's. A reboot of the switch appears to temporally fix this however it appears to come back after a short period of time. We have swapped the switch for another same make and model and there is no issues. We are running code 17.6.4 and according to Cisco bug search we should not be hitting bug CSCvs52594.
Does anyone know of any power issues with 9200L's or should I start replacing the switches via Cisco RMA?
23 Replies 23
9200L switch ,some ports could't be afford power for cisco phone 7481,
Switch Ports Model SW Version SW Image Mode
* 1 52 C9200L-48P-4X 17.12.03 CAT9K_LITE_IOSXE INSTALL
   2 52 C9200L-48P-4X 17.12.03 CAT9K_LITE_IOSXE INSTALL
SW192.56#
Jul 24 04:38:46.865: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:38:47.850: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 24 04:38:49.855: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:38:49.859: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Cont roller reports power Imax error detected
Jul 24 04:38:51.813: %SSH-5-SSH_CLOSE: SSH Session from 172.21.6.90 (tty = 0) for user '' using crypto cip her '' closed
Jul 24 04:38:59.865: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:39:00.850: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 24 04:39:02.857: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:39:02.862: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Cont roller reports power Imax error detected
Jul 24 04:39:07.478: %SSH-5-SSH_CLOSE: SSH Session from 172.21.127.220 (tty = 0) for user '' using crypto cipher '' closed
Jul 24 04:39:12.865: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:39:13.850: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 24 04:39:15.856: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 24 04:39:15.860: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Cont roller reports power Imax error detected
Connect the phone directly to the switch and see if the same error message appears or not.
yes, connect use 1.5M cable ,same error . today i test update IOS to 17.9.3, only work 3 min, when switch restart . then same error.
Please post the complete output to the following commands:
sh interface Gi1/0/30 controll
sh power inline G1/0/3 detail
sh platform pm interface-flaps Gi1/0/3
CN-PIR-YANZHOU-SW192.56#show interfaces gi1/0/30 controller
GigabitEthernet1/0/30 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 4488.16ae.f01e (bia 4488.16ae.f01e)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 04:43:41, output 04:43:16, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2969 packets input, 1022447 bytes, 0 no buffer
Received 139 broadcasts (92 multicasts)
0 watchdog, 92 multicast, 0 pause input
5201 packets output, 2619343 bytes, 0 underruns
Output 436 broadcasts (1084 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet1/0/30 Receive
2619343 Total bytes 1022447 Total bytes
3681 Unicast frames 2830 Unicast frames
2391298 Unicast bytes 1007050 Unicast bytes
1084 Multicast frames 92 Multicast frames
185321 Multicast bytes 9953 Multicast bytes
436 Broadcast frames 47 Broadcast frames
42724 Broadcast bytes 5444 Broadcast bytes
0 System FCS error frames 0 IpgViolation frames
0 MacUnderrun frames 0 MacOverrun frames
0 Pause frames 0 Pause frames
0 Cos 0 Pause frames 0 Cos 0 Pause frames
0 Cos 1 Pause frames 0 Cos 1 Pause frames
0 Cos 2 Pause frames 0 Cos 2 Pause frames
0 Cos 3 Pause frames 0 Cos 3 Pause frames
0 Cos 4 Pause frames 0 Cos 4 Pause frames
0 Cos 5 Pause frames 0 Cos 5 Pause frames
0 Cos 6 Pause frames 0 Cos 6 Pause frames
0 Cos 7 Pause frames 0 Cos 7 Pause frames
0 Oam frames 0 OamProcessed frames
0 Oam frames 0 OamDropped frames
1164 Minimum size frames 1161 Minimum size frames
1321 65 to 127 byte frames 631 65 to 127 byte frames
892 128 to 255 byte frames 295 128 to 255 byte frames
208 256 to 511 byte frames 265 256 to 511 byte frames
173 512 to 1023 byte frames 187 512 to 1023 byte frames
1443 1024 to 1518 byte frames 430 1024 to 1518 byte frames
0 1519 to 2047 byte frames 0 1519 to 2047 byte frames
0 2048 to 4095 byte frames 0 2048 to 4095 byte frames
0 4096 to 8191 byte frames 0 4096 to 8191 byte frames
0 8192 to 16383 byte frames 0 8192 to 16383 byte frames
0 16384 to 32767 byte frame 0 16384 to 32767 byte frame
0 > 32768 byte frames 0 > 32768 byte frames
0 Late collision frames 0 SymbolErr frames
0 Excess Defer frames 0 Collision fragments
0 Good (1 coll) frames 0 ValidUnderSize frames
0 Good (>1 coll) frames 0 InvalidOverSize frames
0 Deferred frames 0 ValidOverSize frames
0 Gold frames dropped 0 FcsErr frames
0 Gold frames truncated
1 Gold frames successful
0 1 collision frames
0 2 collision frames
0 3 collision frames
0 4 collision frames
0 5 collision frames
0 6 collision frames
0 7 collision frames
0 8 collision frames
0 9 collision frames
0 10 collision frames
0 11 collision frames
0 12 collision frames
0 13 collision frames
0 14 collision frames
0 15 collision frames
0 Excess collision frames
LAST UPDATE 16993552 msecs AGO
CN-PIR-YANZHOU-SW192.56# show pow
CN-PIR-YANZHOU-SW192.56# show power in
CN-PIR-YANZHOU-SW192.56# show power inline gi1/0/30 de
CN-PIR-YANZHOU-SW192.56# show power inline gi1/0/30 detail
Interface: Gi1/0/30
Inline Power Mode: auto
Operational status: faulty
Device Detected: no
Device Type: n/a
IEEE Class: n/a
Discovery mechanism used/configured: Ieee and Cisco
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 0.0
Power available to the device: 0.0
Actual consumption
Measured at the port: 0.0
Maximum Power drawn by the device since powered on: 0.0
Absent Counter: 0
Over Current Counter: 0
Short Current Counter: 0
Invalid Signature Counter: 0
Power Denied Counter: 0
Power Negotiation Used: None
LLDP Power Negotiation --Sent to PD-- --Rcvd from PD--
Power Type: - -
Power Source: - -
Power Priority: - -
Requested Power(W): - -
Allocated Power(W): - -
Four-Pair PoE Supported: No
Spare Pair Power Enabled: No
Four-Pair PD Architecture: N/A
Perpetual POE Enabled: FALSE
Fast POE Enabled: FALSE
CN-PIR-YANZHOU-SW192.56# show pl
CN-PIR-YANZHOU-SW192.56# show platform pc
CN-PIR-YANZHOU-SW192.56# show platform pm
CN-PIR-YANZHOU-SW192.56# show platform pm in
CN-PIR-YANZHOU-SW192.56# show platform pm interface-f
CN-PIR-YANZHOU-SW192.56# show platform pm interface-flaps gi1/0/30
Field AdminFields OperFields
Access Mode Multi-Static Multi-Static
Access Vlan Id 4 0
Voice Vlan Id 172 172
VLAN Unassigned 1
ExAccess Vlan Id 32767
Native Vlan Id 1
Port Mode access none
Encapsulation 802.1Q 802.1Q
disl trunk off
Media unknown
DTP Nonegotiate 0 0
Port Protected 0 0
Unknown Unicast Blocked 0 0
Unknown Multicast Blocked 0 0
Vepa Enabled 0 0
App interface 0 0
Span Destination 0
Duplex auto auto
Default Duplex auto
Speed auto auto
Auto Speed Capable 1 1
No Negotiate 0 0
No Negotiate Capable 0 0
Flow Control Receive ON Off
Flow Control Send Off Off
Jumbo 0 0
saved_holdqueue_out 0
saved_input_defqcount 2000
Jumbo Size 1500
Forwarding Vlans : none
Current Pruned Vlans : none
Previous Pruned Vlans : none
Sw LinkNeg State : LinkStateDown
No.of LinkDownEvents : 4
XgxsResetOnLinkDown(10GE):
Time Stamp Last Link Flapped(D) : Jul 25 00:57:47.763
LastLinkDownDuration(sec) 17055
LastLinkUpDuration(sec): 43
CN-PIR-YANZHOU-SW192.56#show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 404 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 406 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.con
Trap logging: level alerts, 0 message lines logged
Logging to 10.130.26.84 (udp port 514, audit disabled,
link down),
0 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging to 10.130.2.210 (udp port 514, audit disabled,
link down),
filtering disabled
Logging to 10.130.2.218 (udp port 514, audit disabled,
link down),
filtering disabled
Logging Source-Interface: VRF Name:
TLS Profiles:
Log Buffer (4096 bytes):
3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:43:22.731: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:23.716: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:43:24.722: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:24.726: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:43:34.732: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:35.718: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:43:36.722: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:36.726: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:43:46.734: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:47.728: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:43:48.721: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:48.725: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:43:58.728: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:43:59.717: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:44:00.721: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:00.725: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:44:10.728: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:11.716: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:44:12.722: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:12.726: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:44:22.733: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:24.716: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:44:26.723: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:26.727: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:44:36.732: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:38.717: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:44:40.721: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:40.725: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:44:50.728: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:52.716: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:44:54.723: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:44:54.727: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:45:04.732: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:45:06.717: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:45:08.723: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:45:08.727: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Jul 25 05:45:18.733: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:45:19.717: %ILPOWER-5-DETECT: Interface Gi1/0/30: Power Device detected: IEEE PD
Jul 25 05:45:21.722: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
Jul 25 05:45:21.726: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/30: Power Controller reports power Imax error detected
Try a different port.
And post the complete output to the command "sh post".
we ues gi1/0/28 test , same port status notconnect ,but have power out.
only few ports have this problem , not all ,  our switch some port broken ?
CN-PIR-YANZHOU-SW192.56#show post
Stored system POST messages:
Switch 1
POST: CRYPTO Tests : Begin
POST: CRYPTO Tests : End, Status Passed
POST: PORT Loopback: loopback Test : Begin
POST: PORT Loopback: loopback Test : End, Status Passed
POST: SIF Tests : Begin
POST: SIF Tests : End, Status Passed
POST: Thermal, Temperature Tests : Begin
POST: Thermal, Temperature Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
Switch 2
CN-PIR-YANZHOU-SW192.56# show platform pm interface-flaps gi1/0/28
Access Vlan Id 4 0
VLAN Unassigned 1
Native Vlan Id 1
disl trunk off
Media unknown
DTP Nonegotiate 0 0
Port Protected 0 0
Vepa Enabled 0 0
App interface 0 0
Span Destination 0
Duplex auto auto
Default Duplex auto
Speed auto auto
No Negotiate 0 0
Jumbo 0 0
Jumbo Size 1500
Time Stamp Last Link Flapped(D) : Jul 25 00:57:47.752
LastLinkDownDuration(sec) 20691
LastLinkUpDuration(sec): 78
CN-PIR-YANZHOU-SW192.56# show interfaces gi1/0/28 controller
GigabitEthernet1/0/28 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 4488.16ae.f01c (bia 4488.16ae.f01c)
Last input 05:45:04, output 05:44:54, output hang never
277 packets input, 47123 bytes, 0 no buffer
Received 176 broadcasts (99 multicasts)
0 watchdog, 99 multicast, 0 pause input
3469 packets output, 572866 bytes, 0 underruns
Output 873 broadcasts (2269 multicasts)
0 output errors, 0 collisions, 2 interface resets
Transmit GigabitEthernet1/0/28 Receive
572866 Total bytes 47123 Total bytes
327 Unicast frames 101 Unicast frames
97801 Unicast bytes 24953 Unicast bytes
2269 Multicast frames 99 Multicast frames
382385 Multicast bytes 12652 Multicast bytes
873 Broadcast frames 77 Broadcast frames
92680 Broadcast bytes 9518 Broadcast bytes
338 Minimum size frames 53 Minimum size frames
1684 65 to 127 byte frames 149 65 to 127 byte frames
1220 128 to 255 byte frames 51 128 to 255 byte frames
96 256 to 511 byte frames 10 256 to 511 byte frames
97 512 to 1023 byte frames 3 512 to 1023 byte frames
19 1024 to 1518 byte frames 8 1024 to 1518 byte frames
15 1519 to 2047 byte frames 3 1519 to 2047 byte frames
LAST UPDATE 20691436 msecs AGO
CN-PIR-YANZHOU-SW192.56# show power inline gigabitEthernet1/0/28 detail
Interface: Gi1/0/28
Operational status: on
Device Detected: yes
Device Type: Ieee PD
IEEE Class: 1
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 3.7
Power available to the device: 3.7
Actual consumption
Maximum Power drawn by the device since powered on: 2.1
Absent Counter: 0
Power Negotiation Used: CDP
Power Type: - -
Power Source: - -
Power Priority: - -
CN-PIR-YANZHOU-SW192.56#show inter status
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/2 connected 4 a-full a-100 10/100/1000BaseTX
Gi1/0/3 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/4 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/5 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/6 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/7 4A007 purchasing connected 175 a-full a-100 10/100/1000BaseTX
Gi1/0/8 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/9 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/10 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/11 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/12 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/13 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/14 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/15 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/16 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/17 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/18 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/19 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/20 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/21 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/22 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/23 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/24 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/25 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/26 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/27 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/28 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/29 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/30 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/31 4A031-Purchase-Int notconnect 175 auto auto 10/100/1000BaseTX
Gi1/0/32 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/33 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/34 connected 4 a-full a-100 10/100/1000BaseTX
Gi1/0/35 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/36 connected 4 a-full a-100 10/100/1000BaseTX
Gi1/0/37 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/38 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/39 connected 175 a-full a-1000 10/100/1000BaseTX
Gi1/0/40 4A040 notconnect 175 auto auto 10/100/1000BaseTX
Gi1/0/41 4A041-HaiGuan-Inte connected 175 a-full a-10 10/100/1000BaseTX
Gi1/0/42 4A042 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/43 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/44 notconnect 4 auto auto 10/100/1000BaseTX
Gi1/0/45 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/46 connected 4 a-full a-100 10/100/1000BaseTX
Gi1/0/47 connected 4 a-full a-1000 10/100/1000BaseTX
Gi1/0/48 connected 4 a-full a-1000 10/100/1000BaseTX
Te1/1/1 notconnect 1 auto auto unknown
Te1/1/2 notconnect 1 auto auto unknown
Te1/1/3 notconnect 1 auto auto unknown
Te1/1/4 SW192.55 connected trunk full 10G SFP-10GBase-LR
Gi2/0/1 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/2 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/3 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/4 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/5 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/6 connected 175 a-full a-1000 10/100/1000BaseTX
Gi2/0/7 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/8 connected 4 a-full a-100 10/100/1000BaseTX
Gi2/0/9 connected 4 a-full a-100 10/100/1000BaseTX
Gi2/0/10 connected 4 a-full a-100 10/100/1000BaseTX
Gi2/0/11 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/12 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/13 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/14 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/15 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/16 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/17 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/18 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/19 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/20 notconnect 175 auto auto 10/100/1000BaseTX
Gi2/0/21 notconnect 175 auto auto 10/100/1000BaseTX
Gi2/0/22 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/23 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/24 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/25 connected 4 a-full a-100 10/100/1000BaseTX
Gi2/0/26 connected 4 a-full a-10 10/100/1000BaseTX
Gi2/0/27 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/28 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/29 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/30 4A078-huangli connected 175 a-full a-10 10/100/1000BaseTX
Gi2/0/31 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/32 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/33 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/34 connected 4 a-full a-1000 10/100/1000BaseTX
Gi2/0/35 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/36 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/37 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/38 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/39 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/40 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/41 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/42 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/43 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/44 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/45 connected 4 a-full a-100 10/100/1000BaseTX
Gi2/0/46 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/47 notconnect 4 auto auto 10/100/1000BaseTX
Gi2/0/48 connected 4 a-full a-100 10/100/1000BaseTX
Te2/1/1 notconnect 1 auto auto unknown
Te2/1/2 notconnect 1 auto auto unknown
Te2/1/3 notconnect 1 auto auto unknown
Te2/1/4 notconnect 1 auto auto unknown
CN-PIR-YANZHOU-SW192.56#show pow
CN-PIR-YANZHOU-SW192.56#show power in
CN-PIR-YANZHOU-SW192.56#show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 740.0 69.6 670.4
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto off 0.0 n/a n/a 30.0
Gi1/0/2 auto on 6.3 IP Phone 7942 2 30.0
Gi1/0/3 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto off 0.0 n/a n/a 30.0
Gi1/0/11 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/12 auto off 0.0 n/a n/a 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
Gi1/0/16 auto off 0.0 n/a n/a 30.0
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/25 auto off 0.0 n/a n/a 30.0
Gi1/0/26 auto off 0.0 n/a n/a 30.0
Gi1/0/27 auto off 0.0 n/a n/a 30.0
Gi1/0/28 auto on 3.7 Ieee PD 1 30.0
Gi1/0/29 auto off 0.0 n/a n/a 30.0
Gi1/0/30 auto off 0.0 n/a n/a 30.0
Gi1/0/31 auto off 0.0 n/a n/a 30.0
Gi1/0/32 auto off 0.0 n/a n/a 30.0
Gi1/0/33 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/34 auto on 6.3 IP Phone 7942 2 30.0
Gi1/0/35 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/36 auto on 6.3 IP Phone 7942 2 30.0
Gi1/0/37 auto off 0.0 n/a n/a 30.0
Gi1/0/38 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/39 auto off 0.0 n/a n/a 30.0
Gi1/0/40 auto off 0.0 n/a n/a 30.0
Gi1/0/41 auto off 0.0 n/a n/a 30.0
Gi1/0/42 auto off 0.0 n/a n/a 30.0
Gi1/0/43 auto off 0.0 n/a n/a 30.0
Gi1/0/44 auto off 0.0 n/a n/a 30.0
Gi1/0/45 auto on 3.7 IP Phone 7841 1 30.0
Gi1/0/46 auto on 6.3 IP Phone 7942 2 30.0
Gi1/0/47 auto on 3.7 IP Phone 7841 1 30.0
(Watts)
Gi1/0/48 auto on 3.7 IP Phone 7841 1 30.0
Totals: 16 on 69.6
2 740.0 74.8 665.2
(Watts)
Gi2/0/1 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/2 auto off 0.0 n/a n/a 30.0
Gi2/0/3 auto off 0.0 n/a n/a 30.0
Gi2/0/4 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/5 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/6 auto off 0.0 n/a n/a 30.0
Gi2/0/7 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/8 auto on 6.3 IP Phone 7942 2 30.0
Gi2/0/9 auto on 6.3 IP Phone 7942 2 30.0
Gi2/0/10 auto on 6.3 IP Phone 7942 2 30.0
Gi2/0/11 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/12 auto off 0.0 n/a n/a 30.0
Gi2/0/13 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/14 auto off 0.0 n/a n/a 30.0
Gi2/0/15 auto off 0.0 n/a n/a 30.0
(Watts)
Gi2/0/16 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/17 auto off 0.0 n/a n/a 30.0
Gi2/0/18 auto off 0.0 n/a n/a 30.0
Gi2/0/19 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/20 auto off 0.0 n/a n/a 30.0
Gi2/0/21 auto off 0.0 n/a n/a 30.0
Gi2/0/22 auto off 0.0 n/a n/a 30.0
Gi2/0/23 auto off 0.0 n/a n/a 30.0
Gi2/0/24 auto off 0.0 n/a n/a 30.0
Gi2/0/25 auto on 6.3 IP Phone 7942 2 30.0
Gi2/0/26 auto off 0.0 n/a n/a 30.0
Gi2/0/27 auto off 0.0 n/a n/a 30.0
Gi2/0/28 auto off 0.0 n/a n/a 30.0
Gi2/0/29 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/30 auto off 0.0 n/a n/a 30.0
Gi2/0/31 auto off 0.0 n/a n/a 30.0
Gi2/0/32 auto off 0.0 n/a n/a 30.0
Gi2/0/33 auto off 0.0 n/a n/a 30.0
Gi2/0/34 auto on 3.7 IP Phone 7841 1 30.0
Gi2/0/35 auto off 0.0 n/a n/a 30.0
Gi2/0/36 auto off 0.0 n/a n/a 30.0
Gi2/0/37 auto off 0.0 n/a n/a 30.0
Gi2/0/38 auto off 0.0 n/a n/a 30.0
Gi2/0/39 auto off 0.0 n/a n/a 30.0
Gi2/0/40 auto off 0.0 n/a n/a 30.0
Gi2/0/41 auto off 0.0 n/a n/a 30.0
Gi2/0/42 auto off 0.0 n/a n/a 30.0
(Watts)
Gi2/0/43 auto off 0.0 n/a n/a 30.0
Gi2/0/44 auto off 0.0 n/a n/a 30.0
Gi2/0/45 auto on 6.3 IP Phone 7942 2 30.0
Gi2/0/46 auto off 0.0 n/a n/a 30.0
Gi2/0/47 auto off 0.0 n/a n/a 30.0
Gi2/0/48 auto on 6.3 IP Phone 7942 2 30.0
Totals: 16 on 74.8
Is this happening to ALL phones or just one phone?
we test 3 cisco 7841 phone, not work .
in before test, when we connect other switch , 2 cisco phone can be work , the last one not test , we  guess problem not in phone.
