Catalyst 9300 - DHCP snooping and VXLAN
Hi all,
I'm currently testing the Catalyst 9300.
It's configured as a VXLAN leaf, here the base configuration of VXLAN/BPG EVPN:
l2vpn evpn
replication-type static
vlan configuration 84
member evpn-instance 84 vni 11084
interface GigabitEthernet1/0/1
description "End host"
switchport access vlan 84
spanning-tree portfast
interface TenGigabitEthernet1/1/1
description "To spine"
no switchport
ip unnumbered Loopback0
ip pim sparse-mode
ip router isis
ip lisp source-locator Loopback0
interface nve1
no ip address
source-interface Loopback0
host-reachability protocol bgp
member vni 11084 mcast-group 239.1.1.84
router bgp 65501
bgp router-id interface Loopback0
bgp log-neighbor-changes
bgp graceful-restart
neighbor 10.30.8.1 remote-as 65501
neighbor 10.30.8.1 update-source Loopback0
address-family ipv4
no neighbor 10.30.8.1 activate
exit-address-family
address-family l2vpn evpn
neighbor 10.30.8.1 send-community both
maximum-paths 4
exit-address-family
ip pim rp-address 10.30.8.1
ip pim ssm default
This conf with VXLAN is working fine.
Now, I would like to enable DHCP snooping. I added these commands:
ip dhcp snooping vlan 84
ip dhcp snooping
But how to add the trusted interface for the snooping ?
I find nothing is the docs, in fact is DHCP snooping supported for VXLAN's VLAN ?
Thanks in advance for help.
Olivier
Sorry for that. It's the same for the Catalyst 9300:
DHCP snooping (Dynamic Host Configuration Protocol snooping) is not supported on VXLAN VLANs.
Go to the Guidelines and Limitations in the document attached:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/lyr2/b_169_lyr2_9300_cg/configuring_vxlan_bgp_evpn.html#id_79178
Hi Georg,
Thanks for the answer, but it's for Nexus switches.
I'm wondering if it's the same for the Catalyst 9000 family ?
