Catalyst 9600 throughput calculation
adamgibs7
Level 6
Level 6
Dears
Anybody can explain me the through put performance for catalyst 9600 switch , hence it show hardware ready upto 25.6 ( 6.4/slot x 4 slot = 25.6,,, Please correct me if i m wrong, but this is not the way we use to calculate to other modular switches for example 9400 the math is
10 Slot chassis
8 slots *80 Gbps/slot = 640,,  multiply X 2 for full duplex so 640 x 2= 1280 Gbps.
do we have to add supervisor throughput also if so then  1 Supervisor will be active at a time so the math is 80 X 2 = 160 so the total comes to 1280 + 160 = 1440 ( slot bandwidth + Supervisor slot bandwidth)  this is what the figure is mentioned for the supervisor throughput in datasheet.
Can any body help  me to understand the maths for 9600 throughput.
0 Replies 0
