Catalyst 9K - Macro function?
Maximus
Frequent Visitor
Frequent Visitor
One of my clients uses the macro function on their Catalyst 2960 access switches.
This macro is of this type:
macro auto execute XXX {
conf
$ INTERFACE interface
switchport access vlan 508
switchport voice vlan 210
no service-policy input QOS-BA-User
service-policy input QOS-BA-CALL_Center
We are currently on a renewal project in Catalyst 9K, according to me the features in IOS and IOS-XE is found in IOS-XE Catalyst 9K but I could not find confirmation.
Can you help me please?
Andersjul
Hi Maxime,
I'm not able to find any information about the support for macro on Catalyst 9300. I'll suggest you use the feature navigator: Cisco Feature Navigator - Cisco Systems
What event do your macro trigger upon?
You will most likely be able to create a Python script that configure the ports on the Catalyst 9300.
/Anders
Hi Anders,
Thanks for your feedback !
I just checked the feature navigator, and the macro functions all relate to IOS:
-> Should I assume that what is available on IOS is also available on IOS-XE and Catalyst 9000?
Thank you !
