Catalyst C4510+E Bundle
Good afternoon,
I am making a configuration using the CCW for a bundle:WS-C4510RE-S7+96V+
This bundle is compose with the following: 4510R+E Chassis, Two WS-X4748-RJ45V+E, Sup7-E
Inside the configuration options there is the option to select:
C4500E-S7-UPOE
WS-X4748-UPOE+E Upgrade for Bundles
I have the following question, If i choose the option of upgrade: C4500E-S7-UPOE, this means the two ws-x4748-rj45v+E will be replace with two
WS-X4748-UPOE+E line cards? Or it is a software upgrade of some kind?
Thanks in advance.
Ankur Arora
Roberto,
It is not any kind of software upgrade. It's just the hardware as you will get 2 POE supported line cards.
Ankur
"Please rate the post if found useful"
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe it's physically different line cards.
Ankur Arora
Roberto,
Ankur
