Catalyst IP Segmentation
MaraVarma
Community Member
I am trying to segment a class C ip addresses into a /25 segment and a few /29 segment.
I attached the diagram.
The equipment connected to layer 2 switch does not getting internet access.
What am i missing.
Router Config
interface GigabitEthernet0/0
ip address N.N.N.53 255.255.255.254
duplex auto
speed auto
interface GigabitEthernet0/1
ip address X.X.X.1 255.255.255.248
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 N.N.N.52
ip route X.X.X.8 255.255.255.248 X.X.X.2
ip route X.X.X.128 255.255.255.128 X.X.X.2
Layer 3 Switch Config
interface GigabitEthernet1/0/1
no switchport
ip address X.X.X.2 255.255.255.248
interface GigabitEthernet1/0/2
switchport access vlan 20
switchport mode access
interface GigabitEthernet1/0/3
switchport access vlan 30
interface Vlan20
ip address X.X.X.129 255.255.255.128
interface Vlan30
ip address X.X.X.9 255.255.255.248
ip route 0.0.0.0 0.0.0.0 X.X.X.1
Layer 2 Switch Config
interface Vlan20
ip address X.X.X.130 255.255.255.128
Mark Elsen
   - @MaraVarma             Enable ip routing on the 3850  and execute the command show ip route
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
M02@rt37
Hello @MaraVarma
The configuration look correct, but first thing add ip routing commàdon the Layer 3 switch. Without it, the switch will not route trafic between VLAN 20/VLAN 30 and the router...
Also verify that the VLAN interfaces are up with show ip interface brief command, hosts in VLAN 20 use X.X.X.129 as their default gateway, and the Layer 2 switch has ip default-gatzway x.x.x.129 configured for management.
Pleasr share the output of show ip route command from the L3 switch.
Best regards
Joseph W. Doherty
As the others ( M02@rt37 and @Mark Elsen ) have already noted, you need to insure routing is enabled on the L3 switch.  (Smaller Cisco L3 switches default for routing is usually disabled.  Converse for their large L3 switches
For the L2 switch (for the switch, as a host, management), you should add a default gateway (as also noted by M02@rt37 ).
For routing between the router and L3 switches, you can use either static or dynamic routing.  Although, you have only two L3 devices, I would still use dynamic routing, but that's more of a personal preference, as I believe it's a better choice, but not all would agree.
The static route statements, you have now, should do the job.  As an alternative (for the subnetted /24), on the router, you, I believe, could also use a single static route statement:
Ip route X.X.X.0 255.255.255.255 X.X.X.2
(Student excersize why this would work.)
Giuseppe Larosa
Hello @MaraVarma ,
in addition to the notes about enabling ip routing on the L3 switch made by other colleagues.
for public Internet access from vlan 20,30 behind the L3 switch you need also appropriate NAT statements on the router.
you will need
int gi0/0
! interface to the ISP
ip nat outside
int gi0/1
ip nat inside
exit
in global config
! access-list that defines the source IP addresses to be NATTed all the subnets within the /24
access-list 10 permit X.X.X.0 0.0.0.255
! global command that enable source NAT from inside to outside
ip nat inside source list 10 interface gi0/0 overload
Hope to help
Giuseppe
