Showing results forĀ
Search instead forĀ
Did you mean:Ā
Catalyst/Meraki Compatibility
Is there a known compatibility issue with the Catalyst 6880-X and the Meraki MS350 that causes loss of visibility and loss of the ability to configure the Meraki switch through the Meraki Dashboard when the MS350 connects to the  6880-X?
Julio E. Moisa
Hi Anthony,
It should not generate any problem but take in consideration the following suggestions:
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Recommended_Configuration_for_Trunk_Link_to_Non-Meraki_Switches
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
