Catalyst Switch
nnn_sss22
Level 3
Level 3
Hello
Please tell me what is mean by catalyst switch?
Cisco switches called Catalyst Switch? it can also L3 switch?
I agree with Reza, Catalyst is just the name of Cisco Ethernet Switches, the difference with Catalyst and the old Cisco switches are: the software, the old switches were using the CatOS and the current switches are using IOS, IOS XE.
https://supportforums.cisco.com/document/12991286/cisco-catos-vs-ios-commands
Other difference is the hardware, the new ones are more robust switches, high availability, high capacity, innovation, etc.
On the following link you will find most of the Catalyst switches, the new series 3650, 3850, 6800 and 9000 are not included and probably others either.
http://www.bizinetworks.com/cisco-switches.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Reza Sharifi
Catalyst is just the name of the platform series. And yes, they can be L3 as well.
from which series, catalyst switch introduce?
what is different between catalyst switch and old simple cisco switch?
Hope it is useful
