Catlayst 4506-E with SUP 7E
Fraydoon Razazi
Does anyone know if SUP 7E is comatible with IOS? It came with IOS-XE preloaded and there are no IOS software listed under downloades.
Fraydoon
2 Accepted Solutions
InayathUlla Sharieff
HI Fraydoon,
I dont think so you can use any other software on this module as of now.
Inayath
Hi Fraydoon,
the newer platforms like the SUP 7 come with Dual Core Processors.
To use both cores, the IOS architecture was changed from monolithic to a Linux based process/daemon (IOSd).
"What is Cisco IOS XE?":
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps9442/ps11192/ps11194/QA_C67-622903.html
So you have to use IOS-XE, enjoy it ;-)
Hope that helps
Rolf
5 Replies 5
HI Fraydoon,
Inayath
Leo Laohoo
Your statement doesn't make sense.
If you are asking whether the Sup7E can work harmoniously with appliances running CatOS or IOS, then the answer is YES.
But can you load CatOS or Cisco IOS into the Sup7E then the answer is no.
Hi Fraydoon,
Hope that helps
Rolf
HI,
i can see this proceess iosd taking 49 % cpu.Is it normal om cisco 4506e with sup7-E
8539    4056492     634626124 466    49.4 31.7 35.4 0     iosd
ASim,
Couple of reason for the process iosd to be using so much of resource and its not good.
Could you plesae verify if you have confiugred any netflow configuration if yes kindly check the same once again if that is having any issue.
Second check any Multicast issues.
REgards
Inayath
