02-14-2011 10:00 AM - edited 03-06-2019 03:32 PM
We ahve port channel configuer on CatOS switch
configuration looks like this :
set port channel 1/1,2/1 10
We need to add VLANs in this port channel to be allowed what is the exact command for this?
( switchport trunk allowed valns ...) similar to this IOS command.
Thanks in advance
Subodh
Solved! Go to Solution.
02-14-2011 10:50 AM
Hi Subodh,
Yes you will need to do this command one by one on both ports.For example if you wish to allow 601 and 602 on both of the ports,
set trunk 1/1 dot1q desirable 601, 602
set trunk 2/1 dot1q desirable 601, 602
Yes the command should add the new vlan to the already existing list but it will be a safe option to allow all the vlans again along with the new vlan(comma separated list).
Cheers,
Shashank
Please rate the helpful posts.
02-14-2011 10:07 AM
Hi Subodh,
There is no explicit command to allow vlans in catos. This is done using the set trunk command as below:
set trunk 5/1 desirable dot1q 1-1005,1025-4094
Hope that helps,
Shashank
P.S. Please rate if this helped answer your question.
02-14-2011 10:39 AM
Thanks Shashank
we have two ports in a port channel. (1/1 and 2/1)
Means i need to go each port and add VLANs individually. Is my understanding correct?
set trunk 1/1 desirable dot1q 601
set trunk 1/1 desirable dot1q 602
This will add to the existing already permitted VLANs correct?
Please let me know.
Thanks for help !
subodh
02-14-2011 10:50 AM
Hi Subodh,
Cheers,
Shashank
