CBS250-8PP-D stuck in boot loop, Factory reset procedure with button d
Matt O
Good Day all. I just had a CBS250-8PP-D crash on me. Stuck in boot loop, Factory reset procedure with reset button doesn't work. Other than buying a replacement, is there a different way to reset this device?
8 Replies 8
Enes Simnica
hello. Unplug the switch, hold reset for 30 sec, plug it back in while still holding for another 30 sec. If that fails, you might need a replacement.
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Enes Simnica
and check this:
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2634-identify-disable-smartports-CBS.html
more Cisco?!
more Gym?!
Thanks but not sure how thats going to help considering it doesnt full boot
up
Mark Elsen
- @Matt O  Can you post a screenshot or a console trail/output of the issue.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I would. but there is no console port on this device
   - @Matt O          How do you observer the boot loop then (just asking) ?
  M.
       Beauty and terror
      Just keep going
       No feeling is final
I power it on. Watch the status indicator flash for a minute or 2, then
watch the lan ports light up, then back to status led flashing
  - @Matt O    Last hope action = factory reset. If that does not help then RMA
  M.
       Beauty and terror
      Just keep going
       No feeling is final
