CBS350-24NGP-4X - WakeOnLan
Amit-Cohen
I'm using a CBS350-24NGP-4X switch with an Intel® Ethernet Network Adapter I226-T1.
The network card is connected directly to a 5Gb port on the switch.
I understand that Wake-on-LAN (WoL) typically works over 10Mbps, while the 5Gb port only supports 100Mbps and 1Gbps speeds.
Is there any way to get Wake-on-LAN working in this setup? Any suggestions or workarounds would be greatly appreciated.
Thanks!
0 Replies 0
