CBWFQ 75% rule weird behavior
durale1789
I got tested qos cbwfq using iperf and here is my configuration :
class ef
match ip dscp ef
class af21
match ip dscp af21
class af11
match ip dscp af11
policy-map test
class ef
  priority 512
   police 512000 conform-action transmit exceed drop
class af11
  bandwidth remaining  percent 50
class af21
policy-map shape-test
class class-default
  shape average 1024000
  service-policy test
interface s0/0
bandwidth 1024
encapuslation frame-relay
max-reserved-bandwidth 75
service-policy output shape-test
In this configuration I should have for both classes af21 and af11 768-512=256/2 =128k each
However I get up  to 256k on each class af21 or af11 ... like if max-reserved-bandwidth was set  to 100% ...
I can t see any reason for such behavior ... are you ?
5 Replies 5
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Max-reserved-bandwidth doesn't control how CBWFQ actually shares bandwidth, only what class allocations you can define in pre-HQF IOS versions.
Since you shaped at 1 Mbps, and assuming your LLQ used its 512 Kbps, your af11 and af21 classes would split the remaining 512 Kbps evenly, i.e. the 256 Kbps you saw for each.  I.e. it's working correctly.
Hi Joseph,
Since i m using ios 12.4(13)T, it should use HQF instead of pre-HQF. I understand your point to say that it is just a configuration limit so we can easily tweak it as needed up to 100%. However I don t understand why in books I see the following formula:
BW(available) = Max-res * BW - SUM(All BW guaranteed LLC; CBWFQ etc ...)
I have to test again CBWFQ without shaping because I think that since I configured shaping under the class class-default , the Hierarichal Qos may not  follow the 75% rule...
Disclaimer
Posting
Your 12.4(13)T should be pre-HQF, see: http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support.html#wp1118805
smehrnia
Level 7
Level 7
did you assign you policy-map to ur interface? (coz i cant see that )
actually max-reserved-bandwidth only controls how much % of the bandwith is avalaible for allocation only, the rest depends on the flow n config.
to test if everything works fine, try a configuring ur CBWFQ bandwidth allocation to a solid sum of over 768K bandwidth under ur policy-map, see if you get any error.
policy-map test
class er
  priority 512
class af11
  bandwidth 256
class af21
  bandwidth 256
if your config is correct, when you assign this policy-map you MUST get an error.
show policy-map interface s0/0  to verify.
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
policy is bound to the interface
