05-10-2022 01:06 AM
where can I find a copy of the CCC certificate for a Cisco CBS350-24P-4G?
We need it to clear customs of China.
Thanks a lot
Solved! Go to Solution.
05-10-2022 03:12 AM
- Check here : https://pas.cisco.com/pdtcnc
M.
05-10-2022 03:12 AM
M.
05-10-2022 03:47 AM
Got it, thanks a lot
12-11-2024 05:12 PM
Hi Sir may i know how to operate it?
The product which i need CBD250-24p-4G
08-30-2023 11:15 AM
Trying to find a CCC certificate for a CBS350-8P-E-2G we shipped --needed for customs...no response on the links below....best,
08-30-2023 11:15 AM
Trying to find a CCC certificate for a CBS350-8P-E-2G we shipped --needed for customs...best,
12-11-2024 05:11 PM
Hi Sir do you get the certificate??
11-06-2023 02:36 AM
Hi, trying to find the correct CCC cert to ship a C9300L-24T-4X to Shanghai. I can get the cert from the PDTCNC portal for the correct model, but the switch was made in Vietnam and the only CCC cert available states Name and Location of the Factory in China, which doesn't match up. Can anyone help with this?
